Old 10-02-2009, 06:00 PM
92sVx1987 92sVx1987 is offline
so i replaced a fuse and.....
well it was a fuse that was labeled FWD so i i figured that i was only running off the rear tires so i i replaced it and i want to make sure im not just on fwd now ?
Old 10-02-2009, 06:01 PM
Re: so i replaced a fuse and.....
also i kno my writing skills are awful no need to tell me
Old 10-02-2009, 06:09 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
If you have a FWD light on the top left side of your instrument panel then you are only running in FWD instead of AWD, which you shouldnt do for any longer than necessary.
Old 10-02-2009, 06:10 PM
sowise sowise is offline
you just added the fuse in and made it operate in front wheel drive only. Usually used for maintenance and or troubleshooting. You should remove that fuse unless you are having other problems.
Old 10-02-2009, 06:32 PM
wow thx guys appreciate it much
Old 10-02-2009, 11:09 PM
Gamesy's Avatar
Gamesy Gamesy is offline
it will come in handy in case you blow a rear tire
Old 10-02-2009, 11:58 PM
fuse enables RWD for jdm-type trans.....
too foggy now to explain better
must be the swine flu
