Old 09-29-2009, 02:33 PM
WestCoastSVX's Avatar
WestCoastSVX WestCoastSVX is offline
Was MacGyver
Cigarette outlet not working
My 12v outlet inside the car (cigarette lighter) stopped working. I checked the fuse under the dash and the one marked "Cig/Mirror" is fine. Also all functions of the mirrors still work.
Is there another fuse hidden somewhere just for the outlet? Or could the outlet itself have suddenly gone bad?
Troy
1992 SVX LSL "Serenity" 250,000 miles!
I don't care, I'm still free, You can't take the sky from me...
Old 09-29-2009, 02:53 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Cigarette outlet not working
You tried multiple devices in it right??
If you have a mechanics mirror you can pull the ashtray and take a good look at the wire connection to the rear center of it to make sure its still on there. After that its just testing for voltage down the line to the fuse block and battery.
Old 09-29-2009, 04:24 PM
Was MacGyver
Yep, tested three different devices that all worked in our other car right after.
What really made me think it was a blown fuse was the last time it worked was with a plug in compressor inflating a tire (being lazy and not using the real compressor that was buried in the garage). On the third tire and 10 minutes in, it died. I assumed it was the compressor overheating at the time.
Until I tried using something else in the outlet the other day.
Since the fuse at the box is fine, I was thinking there might be a secondary fuse only for the lighter further down the line. But not the case I guess.
Have to investigate and probably take everything apart.
Troy
Old 09-29-2009, 05:18 PM
svxxx26's Avatar
svxxx26 svxxx26 is offline
Headed to Texas...
Interesting! That's an exact replay of what happened when my cigarette lighter quit working. Could not find a fuse blown.
svxcess posted some info on this - about a fusible link on the lighter (he replaced with a wire).
http://www.subaru-svx.net/forum/show...hlight=lighter scroll down to svxcess's post
Jerry
2005 Baja Turbo
2008 Ford Crown Victoria Police Interceptor
jnj7707@yahoo.com
Old 09-29-2009, 07:20 PM
Green1995SVX's Avatar
It's most likely the fusable link on the side of the lighter itself is blown. I hope you have small hands!
Mike
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 09-29-2009, 10:13 PM
It is the fusible link on the back of the socket. I am not sure of its purpose since the circuit is fused but my discovery can be found in THIS POST
Here is a photo of the culprit:
Old 10-01-2009, 12:07 AM
major7venth's Avatar
major7venth major7venth is offline
M7
Really nice post you did on the cigarette lighter fusible link. Great picture,explains it all.. Just a darn cigarette lighter anyway, who would have known..I'm interested to see if its in the S.M., good of Subaru to think of an overheat possibility and have a safety device in place.
Possibly you can help with my 'no shift from 1st gear' problem. I have it posted, Anyway this was excellent.. I am sure its thanks from many..
M7
