Old 09-28-2009, 07:00 AM
macadamianut macadamianut is offline
Angry Help, separate issues or the same??
Hi all,
I just had my timing belt replaced by a mechanic and now I've developed a strange noise coming from the belt/alternator/PS pump area. The noise sounds like a mixture between a rattling shield, bad bearing and belt slap. Is there something in the belt replacement process that could be causing this. This did not occur before the belt replacement.
The other issue (that may be related) is that periodically my warning indicators for battery, brake, stop, and abs come on. This did occur periodically before the belt replacement.
Are they related? How do I fix this??
Thanks,
Mac
__________________________________
1995 SVX-L AWD, green, 98,xxx miles, ECUtune 1.5, mazda RX-8 wheels with subie center caps, stebro muffler, resonator delete, koni inserts, perrin crank pulley, hella 500 off-road lights, power-slot rotors and .....
1993 968 Coupe 6-speed, 80,xxx miles black, H&R springs
Old 09-28-2009, 07:42 AM
dcarrb dcarrb is offline
Re: Help, separate issues or the same??
Check the condition of the crank pulley. Look for a "wobble," and/or rubber protruding from between the inner and outer sections.
dcb
Old 09-28-2009, 03:23 PM
Upon removing the shroud and doing a closer flashlight inspection, I noticed that the area around and under the PS reservoir is wet. PS fill level is below the cold range and barley reading on the dipstick. Will refill and check again for sound and source of leaks.
Could this be the source of my grinding sound?
Thanks
Mac
Old 09-28-2009, 04:23 PM
tiv0's Avatar
tiv0 tiv0 is offline
svxless
Does it only make noise when the wheel is turned?
Trevor
Avondale, AZ
1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13
1992 LS-L Claret 178k totaled 10/26/09
1987 BMW 325is
60% of the time it works, every time
Old 09-28-2009, 05:41 PM
kwren's Avatar
kwren kwren is offline
dcb
crank pulley could even not be re-installed properly or torqued properly.
Keith
no one would ever have a reason to remove a cam shaft pulley to replace a timing belt... would they?
Old 09-28-2009, 06:56 PM
Old Fogey
Thanks
Only if the noise occurs when turning the wheel. The leaking PS may well be an easy O-ring replacement fix to do in the mean time. Look in How-To's under Steering. The PS pump running dry usually means a chattering sound that stops when you stop turning the wheel.
Glenn
Old 09-28-2009, 08:05 PM
kcbsvx's Avatar
kcbsvx kcbsvx is offline
Now down to only ONE!
Mac-
It may be a loose (or slipping due to PS fluid) alternator belt or dying alternator if the dash warning lites are involved.
Glenn-
I met the new owner of the Anniv Edition that I looked at for you. He always wanted one since the debut in 92 and is excited to be driving an SVX.
Christian-
96 SVX Lsi #821, Bordeaux Pearl, 4.44 98 Legacy Trans, Trans Resistor Mod, Dakota Digital Trans Temp Gauge on A-Pillar Pod (awesome), B&M Trans Cooler in Driver's Wheel Well, External Spin-on Trans Filter, Synthetic Fluids in Trans and Diffs, 17x7.5 Primax 695 Rims, Alcyone Rear Panel, Svxfiles' 5000 k HIDs, Clear Headlights, "BOXER6" License Plate, Hard Wired Radar Detector, 94 Power Up Window Switch, Motor Resealed, new Coil Packs, new NGK Iridium Plugs, PVC Valve, Drilled and Slotted Rotors, Gloss Black Calipers and Rotors, EBC Greenstuff Pads, SS Brake Lines, Superb TomsSVX Cat Back Exhaust... SS Resonator, Flowmaster 80 Muffler, Magnaflow Quad SS Tips, Poly Swaybar Bushings, Endlink Mod, Rear Subframe Bushing Mod. Feels great and sounds even better. Thanks to AWD, LLC.
2003 Outback llb H6 3.0 Titanium Pearl- "BOXERR" Mostly Stock
1995 Bmw 325i Conv. Calypso Red- "RBOXER" Modest Mods
2004 Sea Doo Sportster 4-tec 15' Jet Boat, 1494cc, 1454#, 155 HP= <10#/HP Stock
Old 09-28-2009, 08:10 PM
Old Fogey
Originally Posted by kcbsvx View Post
Mac-
Glenn-
Hey Christian! I still managed to buy a rusty one!! Swapped all 4 corners of suspension (Koni), swaybars and links/bushings from my '93 last week. Feels like a new car!! I'm still holding a rearview mirror for you!!
Glenn
Old 09-29-2009, 06:28 AM
I topped off PS fluid- no dice. Seems like a much deeper grinding or slapping sound anyway. I did not notice any belts slapping/loose. But I'm glad I checked PS as I noticed the reservoir leak.
If charging system warning indicator can point to an alternator issue, I'll check that next, and then the crank pulley. It would seem that the noise is coming from the top of the belt system, but that can be hard to tell sometimes.
Is it common for all those indicators to come on together? Battery, stop lamp, brake and abs?
Oh, if it helps- mileage is 79,500.
Mac
Old 09-29-2009, 04:51 PM
Diagnosis...crapped out alternator. Removed belt and noticed a rediculous amount of run-out in the pulley accompanied by a grind/squeek when spun by hand.
Any advice on where to get a new or reman. one for a good price?
Mac
Old 10-01-2009, 02:27 PM
wawazat??'s Avatar
Yeah, I'm still around
Mac,
I may have one (OK, I have multiple alts not sure which or how many are good though). I'll try and get them tested tomorrow and ID a good one for you if you're interested.
Todd
Down to none
Old 10-01-2009, 02:34 PM
kcbsvx's Avatar
Mac- Glad you figured it out.
Glenn- Thanks. I lost my phone in the river, along with all my numbers. Please call me at 413.221.9669.
Christian-
