Old 09-13-2009, 11:17 PM
davew833 davew833 is offline
Pulling a windshield?
Anybody who's pulled a windshield have any tips or tricks? I've tried to pull other non-SVX windshields and always end up breaking them. Is the SVX windshield glued in like others?
davew833@yahoo.com
Former 6-time SVX owner
Old 09-14-2009, 04:33 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: Pulling a windshield?
Yes.............
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 09-14-2009, 04:49 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Have you used guitar string to remove it before? Use the serrated string from a lower chord and use a sawing motion back and forth with a friend on the other side, and do the entire perimeter of the glass.
Old 09-14-2009, 04:53 PM
I used Piano wire
Seth
Past subies:
Other toys:
Old 09-14-2009, 04:57 PM
I used a throttle cable cut out of the SVX I was getting the glass from. It's not the texture of the wire, it's how hot it gets after you saw it back and forth.
Try your best to get between the rubber molding and the body, not between the glass and the rubber molding.
Old 09-14-2009, 05:24 PM
Piano wire, metal guitar string, and throttle cable are all good ideas-- I didn't have a helper available so I went it alone with a box cutter, a steak knife, and a "windshield removal tool" from Harbor Freight.
I started by removing everything from around the windshield that I could, inside and out. Then it took nearly 2 hours of VERY careful work to cut the glass loose, but it was easier than others I've tried because the side and bottom surfaces the windshield mates to are flat rather than recessed (the top is recessed) so I could easily keep my cutting tool parallel to the glass rather than angling the blade and possibly prying against the glass.
LOTS of work and time, but worth it to get a un-chipped, un-pitted (blue) genuine Subaru SVX windshield for $38(!) from the U-pull place.
davew833@yahoo.com
Old 09-14-2009, 07:03 PM
Good score.
