Old 08-29-2009, 08:11 PM
lightweight pulley is smaller than the stock one ?
the stock one is 13cm across the middle and the light weight one is 11cm
it should still work tho ? i think there is still enough of tensioner left to get it to tighten up on the belts
Old 08-29-2009, 08:22 PM
Re: lightweight pulley is smaller than the stock one ?
Lightweight pulleys come in 2 varieties, standard size and underdrive. The underdrive pulleys are smaller, which effectively reduces the drag of your engine accessories on the engine. Did you buy yours used? Underdrive pulleys typically come in a kit with a shorter belt designed to work correctly with the smaller pulley size.
Old 08-29-2009, 08:33 PM
no im sure its not an underdrive one because i saw heaps of underdrive ones when i bought this one and its defiantly bigger than an underdrive one and the listing said stock diameter . yeah i bought it used off eBay it supposedly came off a wrx its an unorthodox racing one it says "p/n 0213101 rev A " on the back of it
Old 08-29-2009, 08:53 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
It will be fine as long as the everything else is correct and aligns ok without rubbing on the timing cover. The difference in diameter is not that much where it will affect the operation of your alternator or power steering. The tensioner has a long adjustment.
Old 08-29-2009, 09:02 PM
ok thanks so-cal and crazy pilot il make sure it clears everything and tightens up properly before i drive with it on , so i guess i can call it slightly underdriven now
Old 09-01-2009, 01:23 PM
kwren's Avatar
kwren kwren is offline
Smaller pulleys are under-drive by definition. Had one and would never recommend putting one on the car... But that is just me. I park a lot on the freeway!
Keith
Old 09-01-2009, 01:24 PM
kwren's Avatar
With the motor running.
