Won't start, second opinion please
I think it is the starter, but would like a second opinion. There is no clicking that I can hear. I parked it, and when I came out, the dash idiot lights come on, but the starter doesn't engage. From the searching I did, I think it would be the starter. Could it be the fusible link, or something along those lines, maybe the relay? There is sufficient voltage at the battery and starter, but can't test the alternator as the engine doesn't turn over. The alternator is a 2 year old Bosch put on by the dealer for the previous owner.
Re: Won't start, second opinion please
Put on the parking brake, and shift the SVX into neutral. Now keep trying to start it by turning the key to start. Try it at least twenty times, preferably with a jump pack hooked up. Then report back. BTW you know that that are two +wires that go to the starter, not counting the ground.
And if THAT does not work, did you recently disconnect the battery?
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
OR, he needs to reset his (anti-theft) alarm system.
hi it seems llike it worked when you parked it ,starters rarely die with out signs ,there is no oem starter relay ,if you have a oem security system there can be a starter inturuped relay in the car ,but personel opinion is your car is suffering from voltage drop, if the battery is good ,buy or make a remote starter button ,its just a tool to help diag cars ,but there are many people here who talk of putting a relay in line ,i did this too but i used a oem 30amp relay from a kit subaru sells for mid 90s to install power outlets
it comes fused and works well ,good luck |
HOTWIRE it!
nobody mentioned it before
"Some work occaisionally is fine, but I bought the car for the road, not for the garage. " BoxerFanatic click here for fuelly mpg info |
Turn on the lights, shine them on something so you can see them, or have someone else observe the results. Turn the key to the start position. If the lights do not dim slightly, the starter is not drawing current. In this event several obvious items are suspect.
If it's daytime you can use the dome light.
Finally got it fixed. Turned out to be more than one cable that was corroded to the point of no copper left. Had to replace a them, all is well again. Thought I'd add that in case someone searches later.
