Old 07-25-2002, 11:28 AM
Zeppelin's Avatar
Zeppelin Zeppelin is offline
Send a message via ICQ to Zeppelin Send a message via AIM to Zeppelin Send a message via Yahoo to Zeppelin
tranny resistor probs
The day after getting back from the meet, my resistor was dead! It acts like the resistor is unplugged and I don't like it! Anybody have a spare one, or know the part number??
I tried cleaning it up then replugging it in and resetting the computer, but that didn't help any..
I'm like a Slinky.. Not really good for anything, but you can't help but smile when you see me tumble down the stairs.
http://stickyvinylgraphics.com/
Old 07-25-2002, 12:20 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: tranny resistor probs
Are you getting the duty solenoid "A" code in your power light? If you do a search on "resistor" in the old Yahoo archive, Richeich93 posted a substitute from a Legacy, I believe (too bad the tranny doesn't work like the resistor does ). It's much less expensive and usually readily availabe in a bone yard, especially in your neck of the woods.
Randy Johnson
Mike Davis -- at Reading VI
Old 07-25-2002, 12:41 PM
Zeppelin's Avatar
Re: Re: tranny resistor probs
And what's that supposed to mean Randy?!?!?!?!
Old 07-25-2002, 02:08 PM
lee lee is offline
I bought a resistor from a local electronics supply house for $1.49. Look for a value between 9 and 15 Ohms (I think nominally about 10.5) with a 20 watt rating. May have to do a simple wiring mod since most won't come with both leads out the same end like the OEM part.
Old 07-25-2002, 02:18 PM
Aredubjay's Avatar
Re: Re: Re: tranny resistor probs
Gee, you're paranoid. I just meant there are a lot more Subarus in your area than there are mine, therefore the part should be easier to find -- sheesh!
Randy Johnson
Old 07-25-2002, 02:36 PM
Zeppelin's Avatar
Angry
Well, I just checked the resistor and it appears to be good.. I checked it with an ohm meter and it has resistance, so I guess my problem is actually Duty Solenoid A.. Where is it located? How soon do I need to fix this?
Old 07-25-2002, 04:08 PM
Aredubjay's Avatar
Duty solenoid A is located in the tranny valve body. It involves a pan drop. It controls line pressure. Without it, you'll get full line pressure at all times. If you like the "slamming" shifts, you can deal with it for a while. I have a diagram of the location on my home computer. I've also posted it to the Network if you want to use the search button.
Randy Johnson
Old 07-25-2002, 11:30 PM
Zeppelin's Avatar
Screw that search button crap!!
You think this would be a job that I could do Randy, or should I persuade the FINE mechaincs at the Subaru dealership to do it for me? These hard shifts suck big time, plus I don't like being able to put it in 3rd to slow my car down.. If I get any tickets because of this, can I send the bill directly to you?
Old 07-26-2002, 08:05 AM
Aredubjay's Avatar
I don't think so. I've never had the valve body off, myself, but, I wouldn't think a solenoid pack wouldn't be that hard to replace. You might check with John McKenna (svxcommuter). I think he may have the "skinny" on the valve body. There may be others. If so, folks, speak up.
(Sorry, I forgot to send the diagram, and I'm back at work, and they're back at home . . . sheesh, getting old an forgetful sucks!)
Randy Johnson
