Old 01-31-2009, 11:51 AM
Mensaf's Avatar
Mensaf Mensaf is offline
What do you mean wrong SVX?
Weird in-cabin noise
I hear this more at low speeds, and sometimes it doesn't start (or I don't notice it) until it shifts. At first I thought it was either the speakers or the blower motor making the noise, since it sounded like an electrical whine of sorts, but when both were off the noise surfaced. I then thought it could be a belt or pulley, but they're all in good working order and there is no noise from the engine bay. It seems as though this whining noise also increases with how far down the throttle is depressed. Any ideas?
Old 01-31-2009, 12:49 PM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Re: Weird in-cabin noise
Describe it more... Is it like a squeaking/squealing? Sounds like it's coming from the passenger side?
Old 01-31-2009, 02:52 PM
stiguy's Avatar
stiguy stiguy is offline
vaccum leak of some sort?
Old 01-31-2009, 03:44 PM
Mensaf's Avatar
This is exactly it.
It SEEMS like it could be, but there aren't any vaccum lines within, are there?
Old 01-31-2009, 04:32 PM
stiguy's Avatar
there should be in the dash that open and close the vent doors . that direct the air to diff vents in your car they are vaccumed controled. i think?
Old 01-31-2009, 04:39 PM
The air path for the HVAC is electrically controlled with motorized levers.
Old 01-31-2009, 04:43 PM
stiguy's Avatar
what about cruze control??
Old 01-31-2009, 05:12 PM
log1call log1call is offline
Get's noisier with throttle... could it be a hydraulic oil noise from the trans?
Old 01-31-2009, 07:28 PM
Mensaf's Avatar
Nevermind. Waterpump What are the odds of Autozone having that, the belt, and all in stock tomorrow?
Old 01-31-2009, 07:53 PM
stiguy's Avatar
3 out of 10 my guess
Old 01-31-2009, 09:55 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Not so good.... and also you may want to get a new timing cover gasket set as well.
Old 02-02-2009, 07:28 AM
Freeman's Avatar
Unregistered User
Water pump? Wasn't my first guess but was a close second. Glad you figured it out and hope it is fixed soon..
Old 02-02-2009, 07:35 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
I wouldnt really recommend the autozone parts when it comes to the cooling system. I had a sticky thermostat that wouldn't open at the correct temperature, and i had to drain everything and refill 3 times before finally installing one that worked.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 02-02-2009, 07:38 AM
Mensaf's Avatar
Yea, just waiting on the parts as of now. If I had the time, I'd change the head gasket while I'm at it just for peace of mind. I've been going back and forth between selling the car for something more tuner/budget friendly, but it's slowly starting settle into a more long term spot in my driveway.
Old 02-02-2009, 07:39 AM
Mensaf's Avatar
Ordered my stuff from the dealer. Price difference wasn't much.
