Old 01-29-2009, 06:58 PM
AyeJaye's Avatar
AyeJaye AyeJaye is offline
A few questions about my new SVX...
So I finally picked my car up today. I put a down payment on it two weeks ago, and since I was paying cash for it they kept it until I paid it off today. Its a 92 LS-L, Black Pearl, 140K miles but still running like its brand new from what I can see so far. Needless to say I've been one happy camper most of the day
Anywho, this is my first SVX (but not my first Subaru) and having had a chance to look over everything a little better I'm left wondering about a few things.
The first thing I looked for when I got home was any evidence of an aftermarket tranny filter. While I wasn't able to get far enough under the car to spot one, I did notice that it does have a smaller front mounted cooler that sits in front of the lower half of the radiator. In all of my reading here I've seen a lot of information about transmission filters and aftermarket coolers, but I didn't see anything about factory coolers. Were these built with stock transmission coolers? (And bear with me if this is a stupid question, believe it or not this is the first auto transmission vehicle I've EVER owned.)
And secondly, did Subaru offer a factory engine block heater in these cars, or was mine added on?
I can't wait to drive to work tomorrow... Though in reality I wish I could just blow off work and drive across the country instead I'll post some pictures once I have a chance to get some good shots.
Old 01-29-2009, 07:30 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: A few questions about my new SVX...
What youre seeing may just be the condenser for the A/C, 92's cool the trans fluid in the radiator. Could have an external trans cooler though, you'll have to see where the lines go. If you have the campaign filter, it will be on the driver side right next to your thermostat housing, and you will see the lines going to the radiator and transmission (looks like a fuel filter). A good quick FAQ to familiarize you with your new SVX can be read on the bottom of my signature (between the ninjas). Congratulations and I hope you enjoy it thoroughly!!
Old 01-29-2009, 07:57 PM
I second checking the line routing. It may be an aftermarket cooler.
Also, the block heater is an OEM accessory. Hold onto that one.
Old 01-29-2009, 08:00 PM
AyeJaye's Avatar
Bookmarked
Old 01-29-2009, 08:17 PM
sperry's Avatar
sperry sperry is offline
$1 is just $1, but $2 = nachos
Originally Posted by AyeJaye View Post
Bookmarked
Keep in mind that while the FAQ is newer than every SVX ever made, it's still like 8 years old. Some of the info in there has been superceeded by new stuff the innovative folks in the SVX community have come up with that hasn't gotten into the FAQ.
But it is a great starting place.
3 turbos, 28 cylinders, 96 valves, 18 cams, 1400hp/1600ftlbs: '09 Outback XT / '06 Outback Sedan / '02 WRX / '94 SVX / '01 F-250 SuperDuty
Old 01-29-2009, 08:28 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Indeed...... Its sometimes needle in a haystack going back over the thousands of threads here, but if you need to know ANYTHING about the SVX, its here. And dont be afraid to ask questions, whether or not they may be already common knowledge (see my own painful "duuuh OHHHH okay" thread titled "Is this an external trans filter")
Old 01-29-2009, 09:17 PM
AyeJaye's Avatar
That's one reason I love this forum. I don't have to put on the proverbial flame suit when I ask a question.
Thanks for the help guys!
Old 01-30-2009, 03:48 PM
AyeJaye's Avatar
So I feel like an idiot. The thing that I thought was an aftermarket tranny cooler is in fact the AC condenser. Oops... So it looks like I'll be adding a tranny cooler and filter as soon as I can afford it.
Having had another day to drive it, I'm noticing that it seems like the front suspension is rattling/knocking when I hit bumps. The steering also seems a tad bit loose and has a slight tendency to wander on me. I don't get any pull when braking, but if I let go of the wheel it goes straight for a bit and then starts pulling to the right slightly. I read somewhere that there was a known problem with the strut mounts on the 92's, does anyone know anything about this or anything else it could potentially be?
Also had a really nasty squeal when I was coming to a stop. They put new brakes on it before they sold it, but I pulled the pads out and put some anti squeal brake goo on the backs of the pads and have almost eliminated the noise. Am curious though whether or not the pads are supposed to have anti rattle plates on the back, as every other Subaru I've owned used them and my SVX does not have them.
Aside from that the only other issue I found was that the sunroof didn't want to open up all the way, and was able to fix that problem easily with the help of another thread on here.
I truly love this car
Old 01-30-2009, 04:12 PM
sperry's Avatar
The anti-squeel plates are usually pad specific. I've had some that came with them, and some that just have an anti-squeel sticker on them, and some with nothing. And even some that came with the sticker in the box but not already on the pads. It's possible that whoever installed the brakes just tossed the plates or stickers, or they could be as-designed.
Keep in mind that if the pads are brand new, they're going to be noisey while they bed in anyway.
Old 01-30-2009, 04:35 PM
Old Fogey
So I feel like an idiot. ..........I'm noticing that it seems like the front suspension is rattling/knocking when I hit bumps.
First.....We all have!!! LOL!!
2nd......Possible balljoints (wear item at this mileage) or front swaybar bushings(usually eaten up by the constant presence of oil leaking from the valve-covers.
3rd.......You may have figured out you're not alone.
Glenn
Old 01-30-2009, 04:59 PM
redlightningsvx's Avatar
Collision Refinishing Tech
The SVX has metal shims for each wheel, 3 per caliper. someone probably just tossed yours.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 01-30-2009, 05:06 PM
AyeJaye's Avatar
One more thing. I've seen a few threads about it but they're a little bit old so I thought I'd bring it up again. Since my current speaker box won't fit in the trunk and I'd like to retain use of my spare tire, is anyone out there still making sub enclosures for the SVX, and could I fit a 12" in it?
92 LS-L, Ebony Pearl, 160k miles, sitting in the hospital waiting room hoping for a miracle
06 Hyundai Sonata GLS, 77K miles
Old 01-30-2009, 05:19 PM
The only one I know of that is custom for our cars is about $700.
Seth
Past subies:
Other toys:
Old 01-30-2009, 05:24 PM
sperry's Avatar
I bet with a jigsaw, glue, nails, and $40 worth of fiberboard & fabric, anyone could make a replica of that $700 box. I'd do it for him ...and for the discount price of only $600!
Old 01-30-2009, 06:28 PM
Yea, $700 bucks is way to much for a sub box.
Seth
Past subies:
Other toys:
