Old 01-26-2009, 11:47 AM
newkid17's Avatar
newkid17 newkid17 is offline
Send a message via AIM to newkid17 Send a message via Yahoo to newkid17
transmission fluid type?
is there a certian type of transmission fluid that i need? i know it needs 10 quarts.
Old 01-26-2009, 11:50 AM
Green1995SVX's Avatar
Re: transmission fluid type?
I've heard a lot of good things about the Genuine Subaru ATF. I have BG Products fluid in mine (original 1992 transmission - never rebuilt) and have no complaints.
http://www.bgprod.com/products/transmission.html
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 01-26-2009, 12:21 PM
newkid17's Avatar
so it really dont matter what goes in it?
Old 01-26-2009, 12:35 PM
Overall, it DOESN'T matter, as long as it's ATF that's compatible with Subaru transmissions. Many people recommend at least using a good synthetic fluid. I use Mobil1 products in my Audi with good results. They're available at any auto parts store.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Nope, toss kool-aid in there!
(I'd wait for more input. A lot of people are very particular about what they put in their car)
Old 01-26-2009, 12:36 PM
HAHA! That's as good as "juice-box".
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 01-26-2009, 12:41 PM
Freeman's Avatar
Unregistered User
Ha! I'm sometimes funny when I make an effort.
Old 01-26-2009, 01:15 PM
dcarrb dcarrb is offline
Type matters, brand doesn't. Use a Dexron fluid.
dcb
Old 01-26-2009, 09:43 PM
Bobb Bobb is offline
Hi everyone, I would just like to point out that fluid levels are sometimes given for an empty transmission. When you drain the transmission on the car, you can't drain all the fluid. I suggest you measure what you drain out and replace with a like amount. An over filled tranny is not a happy tranny! Take care and happy changing, BOBB
Old 01-26-2009, 09:59 PM
Dexron III or compatible multi-use tranny fluid is what you want. I just grab some Quaker State multi-vehicle ATF off the shelf to top up my power steering and tranny as needed.
Old 01-26-2009, 11:30 PM
liamrh's Avatar
liamrh liamrh is offline
Subaru ATF or Redline D4, maybe high-temp.
Royal purple and amsoil have been failing their mcpherson(sp) and shear/shock tests horribly lately.
Old 01-27-2009, 10:48 AM
The only thing about synthetic fluids is that they WILL find leaks. The worst case scenario for that would be an internal leak from the tranny into the front diff, resulting in you needing a new diff. (ATF and gear oil aren't the best of friends)
Old 01-27-2009, 10:00 PM
liamrh's Avatar
Yeah, so what is your point. Most of them are synth anyhow, there is seal conditioners, and ....?
Your pretty much stuck with it for the most part, and the subaru stuff is all, christ, dex IV now?
Old 01-28-2009, 01:57 PM
longassname's Avatar
Just some dude.
That is exceptionally good advice. These transmissions run HOOOOOT if overfilled. I suspect many of the blown SVX transmissions we've seen were cooked after being overfilled. It can be easy to missread the dipstick so I pay particular attention to making sure I get it right--after all the consequences are dire.
The best transmisison fluid you can run is the Subaru ATF which is very inexpensive plus one bottle of lube guard atf protectant.
Old 01-28-2009, 01:59 PM
Just some dude.
no subaru carries different atf for the new boxes and the 4eat's. The correct fluid for our boxes is labled atf/power steering fluid.
