Old 01-27-2009, 02:51 PM
sperry's Avatar
sperry sperry is offline
$1 is just $1, but $2 = nachos
Re: Is this an external trans filter??
Originally Posted by sperry View Post
You can use the timing belt to do it, but it'll likely destroy the belt in the process:
Wrap the belt around the timing gear like this (sorry for the crappy 10 second Visio drawing):
Then loop the other end around something on the motor that will anchor the belt. As you wrench on the gear bolt, the belt tightens on itself and prevents the gear from turning. But this will stretch and kink the timing belt, so don't do it if you plan on reusing the belt!!!
This works for the right cam gear too, if you just kink it under the bottom. I also use the same method with the accessory belt for taking off the crank pulley.
Edit: here are some actual pictures of what I'm talking about:
Bump for the added pictures above. Hopefully that makes more sense about using an old timing belt to take off the cam bolts. I used the same trick to reinstall them too:
One again, if you do this, don't reuse the timing belt!!
3 turbos, 28 cylinders, 96 valves, 18 cams, 1400hp/1600ftlbs: '09 Outback XT / '06 Outback Sedan / '02 WRX / '94 SVX / '01 F-250 SuperDuty
