Old 01-04-2009, 11:01 PM
theallpowerful theallpowerful is offline
Leaking brake line (hard line) on rear of my silver 92
I am leaking brake fluid near the rear-passenger siide wheel. It appears the line has rusted through. It is one of the two lines that run next to the gas tank on the passenger side. This is very strange since my car has virtually NO rust anywhere else. Either way it needs to be fixed. Any pointers? Whats the best place to get a replacement line? Are SS lines available? TIA.
Old 01-05-2009, 12:42 AM
SuberNatural SuberNatural is offline
Re: Leaking brake line (hard line) on rear of my silver 92
Get some pre-flared line from an auto parts store and a $5 line bender and you're good to go.
1992 Liquid Silver/Black LSL
LeveL10 Stage 3 Trans and associated stuff
Old 01-05-2009, 06:41 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Why yes, yes they are. Check with either MS warehouse or click the "Svxfiles" link in black n orange on my SIG for a link to OT's site. They work great!
Old 01-05-2009, 07:23 AM
Green1995SVX's Avatar
Those stainless brake lines are replacements for the rubber lines, not the hard lines.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 01-05-2009, 07:42 AM
Freeman's Avatar
Unregistered User
Right.. I read that a little late.. Thanks for the correction!
...Maybe I need new hard lines too?
Old 01-05-2009, 08:12 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Most hard lines will rot from the inside out when fluid isn't changed. They usually are a PITA to replace as the steel used on the bolts is as strong as rubber! As was already stated you can get preflared lines in various lengths at most parts stores. Be careful though as you need to know the thread count as there are a couple different ones out there. Measure what you have to replace, find one which is close, get it and a bender so you don't kink it, get yourself a bleeder set up, a brake line wrench (has a couple of extra tabs to get a better grip) and I've had very good luck with valvoline synthetic fluid. Get the large bottle and replace all your fluid when you do it.
Old 01-05-2009, 08:57 AM
Old Fogey
Be thankful it's the pass side line. Those lines are a beotch to R&R if you attempt to tackle replacement rather than spot-repair. That line only runs to a join in front of the RR wheel.
Glenn
Old 01-05-2009, 03:42 PM
Like benebob said they rot from the inside out. Brake fluid is hygroscopic, it absorbs water from the air and over time the lines rust from the inside. Brake fluid is one of those forgotten fluids that a lot of people never flush.
Old 01-05-2009, 04:58 PM
Tuck's Avatar
Tuck Tuck is offline
Having just done both rear lines in the last two months I'll suggest that you get the factory lines or you will spend about a week trying to get all the bends in the right place. I paid under $40 for each of mine. It is easier if you drop the rear subframe about six inches also.
Tuck
Old 01-13-2009, 10:31 PM
I ended up ordering them from the dealer. They were about $40 a piece as stated before. I'll see how the replacement goes when they come in.
