Old 01-03-2009, 09:50 AM
dennyo dennyo is offline
Question tire question
wonder what you guys think about using two different brands of snows.both sets are the same size(stock) and both are winter tires with similar tread patterns so i wouldn't think it would be tough on the diffs or am i wrong? thanks dennis
Old 01-03-2009, 12:45 PM
kwren's Avatar
kwren kwren is offline
Re: tire question
don't know... but if that was what I had I wouldn't be afraid to use them.
Might check to see if the information is available on each brand for the circumference measurement, or just measure them yourself with a tape measure?
Keith
Old 01-03-2009, 02:09 PM
Re: tire question
The standard answer is that if you change tires, you must change all at the same time, not 2 on front and not change back ones. If there are different tire treads, that is also a no no. I would not do it, and I think many others here would not either. It is up to you though.
Old 01-03-2009, 09:49 PM
Re: tire question
I've got 2 different sets of snows but when I measured them all four tires are less than 1/4" different in circumference. I think that's the main issue.
Old 01-03-2009, 11:22 PM
kwren's Avatar
Re: tire question
so do I... back to logic!
Keith
Old 01-04-2009, 07:19 AM
Re: tire question
thanks to all. i guess i'll just put on 4 of the same.now i'm wondering how big a difference in circumference would be to be a problem.ie. 1/4" 1/2"?
Old 01-04-2009, 07:37 AM
Re: tire question
1/4" is the magic number I've heard.
