Old 12-26-2008, 07:32 PM
Maxo's Avatar
Maxo Maxo is offline
Crank pully nut
I have the engine out for a complete reseal, water pump, and timing belt change but can't figure out how to get the crank pully off without damaging something... The nut is on there pretty tight.
I'd like to wedge something in the flexplate but that seems like it would be an unwise decision. Is it safe to use an impact wrench on that crank nut? Also, what should I torque it to once I put it back on?
Thanks in advance!
Old 12-26-2008, 07:42 PM
Re: Crank pully nut
Probably your best bet is to block the flex plate and use an impact wrench.
I had one real stubborn one, I had to use a big pipe wrench with a 3 foot pipe on the outer pulley, and a breaker bar with a 3 foot pipe to turn the bolt.
Old 12-26-2008, 09:01 PM
kwren's Avatar
kwren kwren is offline
Re: Crank pully nut
If you run into a snag, use the starter!
Is a bit scary but works like a dream
I use a big break over bar with big old socket and slide a plastic pipe over the handle and brace the whole thing against the frame by the battery. Pad the handle-plastic pipe with some padding to protect the top of fender and turn the ignition switch to start. Turn key off when nut breaks loose... right then!
Old 12-26-2008, 09:59 PM
subbieatnz's Avatar
Re: Crank pully nut
Yep thats whats ive always done to get that bolt off on all my subarus if was needed. Just make sure you put the bar or extention on the side where its turning. put it on the wrong side and it flys an few meters away
1989 Vortex 6 Maroon
1983 RX Silver Grey
Old 12-27-2008, 07:52 AM
Re: Crank pully nut
Yeah, the starter is fine, but;
He'd have to attach the TC and transmission to hold the starter...
Old 12-27-2008, 12:27 PM
svxpert svxpert is offline
Re: Crank pully nut
<<Is it safe to use an impact wrench on that crank nut?>>
its a crank bolt. yes, impact gun will work fine.
Liberalism is a disease. When you can stare at facts and ignore them anyway, you have it.
Old 12-27-2008, 01:04 PM
Maxo's Avatar
Re: Crank pully nut
Yeah the starter trick wont work in my case lol!
Ok great! I guess I'll try and hold the flexplate and use an impact wrench on the nut. I have a torque wrench that's 3' and rated at >500Nm so I think I should be able to get it off even without the impact wrench. If I do bend the flex plate I do have an extra one so at least I'm not sol.
Thanks to all who replied!
Old 12-27-2008, 02:38 PM
Numbchux Numbchux is offline
Re: Crank pully nut
the impact will put the torque on it without turning the motor over.
if that doesn't get it, subaru makes a tool to hold the crank pulley just for this job....might be worth buying/borrowing. where in ND are you? I know a couple guys in Moorhead that might have something.
and next time, break that bolt loose before you pull the motor out
Old 12-27-2008, 03:39 PM
kwren's Avatar
Re: Crank pully nut
Might try a big box end wrench or maybe your breakover bar socket thing with a big mauler (hammer). I have always (many times) loosened mine that way with the exception of the last time after I tightened it too tite. Then I did the starter thingy.
It is important to keep a firm pressure against whatever wrench you chose while you whack it with the mauler.
You can do this!
Keith
Old 12-27-2008, 04:38 PM
Maxo's Avatar
Re: Crank pully nut
Well that's done! The impact wrench made it ridiculously easy to get the bolts off the crank and cams. Cam plugs sure are a pain... Good thing I have new ones, I think I'll end up destroying these trying to get them out.
This reseal is going pretty good, I'm glad I decided to do it myself.
Old 12-27-2008, 04:42 PM
kwren's Avatar
Re: Crank pully nut
Good for you!!
Keith
Old 12-27-2008, 04:59 PM
Maxo's Avatar
Re: Crank pully nut
Is taking off the part that the cam sensor is attached to something I could do to make replacing the cam seals and plugs a piece of cake? I already have the valve cover off and by the look of it, only a few bolts secure that part too.
Old 12-27-2008, 05:44 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: Crank pully nut
Cam plugs I did buy gripping them with some big vice grips and turning back and forth, then hitting the new one in with a hammer. The cam plugs are tricky, to get the old ones out you have to drill a small hole in them and pry them out with a small 90 degree hook.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 12-27-2008, 09:46 PM
Maxo's Avatar
Re: Crank pully nut
They were in there pretty tight and I ended up putting a hole in the top of them then yanking them out with a screwdriver. I'll be glad when this job is done.
Old 12-27-2008, 10:06 PM
Re: Crank pully nut
They suck. I changed my passenger side cam plug with the motor still in, that sucked in general but got it done.
Seth
Past subies:
Other toys:
