Old 12-27-2008, 04:54 PM
Wikedjuggalo's Avatar
Rebuilding
Re: Common things to go out on an eg33
Go ahead and reseal it before you toss it in save you some headache later due to leaking cam seals etc.
Old 12-28-2008, 01:48 PM
wawazat??'s Avatar
Yeah, I'm still around
How many miles are on the engines? If I were you, I'd replace the headgaskets while the engine is out. There have been more than a few that have failed most likely due to age. They have tended to fail and vent pressure to the cooling system.
Your comment on coil issues can be attributed to ham-fisted owners and techs tearing the wires and boots when removing them prior to replacing the plugs or cam cover gaskets. Take your time and the boot can be peeled from the plug body.
Also, replace the cam drive belts and check the idlers when you have it open. When in the front of the motor replace the front end seals and o-rings.
Down to none
