Old 07-08-2002, 09:25 AM
Mr. Pockets's Avatar
Moderator
Crap, a noise
Go figure - two weeks before the Big Meet, my car starts making noises.
From the front left, during tight right-hand turns, I can once in awhile hear a really, really low-pitched squealing. After hearing it, I took the car to an empty parking lot and started swerving around with the windows down. While the howl was absent, I did hear a loud scraping noise.
I suspect that the front caliper is sticking. I may not have greased the slides the last time I took it apart about a month ago.
Any other ideas?
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 07-08-2002, 09:38 AM
immortal_suby's Avatar
Thread Killah
Does it change or go away when you apply the brakes?
Locker Link
2015 BRZ Limited 6MT
Old 07-08-2002, 11:16 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
The backing plate may be a touch too close to the rotor. When turning the rotor may flex just enough to contact the plate. Also another item to investigate are the pad shims, they can slip and touch the rotor also, but generally they'll make noise all the time, not just while turning.
Old 07-08-2002, 12:09 PM
Moderator
That's a really good question - I'll find out tonight.
2005 Outback
END OF LINE
Old 07-08-2002, 12:15 PM
Moderator
I don't suspect the backing plate, because when it squeals, it's a REALLY substantial noise that I hear through the car.
I may just replace the pads. It's been 18 months and just getting a new set with new shims couldn't hurt.
2005 Outback
END OF LINE
