Old 12-23-2008, 06:40 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Tranny has hard time shifting(& more)
Recently, my car seems to be having a difficult time shifting into 3rd gear.. At least I believe it's 3rd gear. Anyway, when I'm driving on the freeway and I have my foot on the throtle, the engine is just loud. I'm moving faster and accelerating just fine but my transmission just won't shift into 3rd.
I attempt to get it to shift by slowing down or speeding up but I can only go so slow and as for going faster, I don't want to blow up the motor..
Sorry if I'm not being very descriptive. I'm not really good at describing my own problems so just ask if you have questions.. Thanks in advance!
Old 12-23-2008, 07:26 AM
Re: Tranny has hard time shifting(& more)
is the car up to full temp when this is happening?? It is common for new owners to ask why the car will not shift into overdrive or lock the torque converter in the winter months. This is due to the following conditions. The trans will not shift into overdrive (4th gear) until the fluid in the pan reaches 50*F and will not lock the t/c until it reaches 150*F.
In my personal experience, some cars will lock the t/c before it reaches 150*F for some reason I cannot explain. While others will not.
Old 12-23-2008, 07:29 AM
Freeman's Avatar
Unregistered User
Yeah, come to think of it, I believe it's only when I first start off driving the car and I never noticed it before the recent freezing tempatures. I wasn't aware of that fact. So I guess I should start warming it up more in the mornings then..
Old 12-23-2008, 07:33 AM
Yes, but warm-up is over rated anymore. Let it warm up for 5-10mins. it won't be at operating temp, but thats OK. The ECU was built and programmed to make up for operation outside of ideal temps and will make up for it. The warm up period is to get the oil thinned out and slippery again.
Its not a problem that you are having, the transmission does this to help the lube warm-up to operating temperature much like a thermostat in a coolant system
Old 12-23-2008, 07:37 AM
Freeman's Avatar
Unregistered User
So there's no risk of anything suddenly exploding or anything like that?
Old 12-23-2008, 07:39 AM
dcarrb dcarrb is offline
Mine can take a mile or more to shift to 4th on really cold mornings (for here, 10-20F), and 8-10 miles for the TC to lock. Unless I have to scrape or defrost the glass, I usually just turn the key and go.
dcb
Old 12-23-2008, 08:52 AM
No... Now this doesn't go to say beat the hell out of it when its cold... You should be driving gingerly
Old 12-23-2008, 09:16 AM
When the torque converter locks up where will the RPMs be around say at 65mph? What will the RPMs be if it is not locking? Just wondering.
Old 12-23-2008, 09:56 AM
on a stock transmission in 4th I believe the rpms are about 2k@60mph w/ the t/c locked. Unlocked it should be around 2250-2500 cruising
Old 12-23-2008, 11:25 AM
On the freeway I often set the cruise at 2500 RPM. That's 72-74 MPH. 3000 RPM = 80+ MPH.
dcb
Old 12-24-2008, 09:45 AM
Freeman's Avatar
Unregistered User
Had dinner at OT's place with "the family" and we went for a test drive. The car was warmed up by then and when we drove there were NO problems... Well no problems pertaining to what we we're looking for anyway.. My steering was off and tranny temp a little high, etc, etc.. but thats for another thread.. Point is, the tranny is fine... for now.
Thanks for the help!!
