Old 12-10-2008, 11:17 PM
liamrh's Avatar
liamrh liamrh is offline
differential crush washer.....
...part number from the stealership? I would appreciate it if someone could provide it to me. Thanks!!
Old 12-11-2008, 08:46 AM
Old Fogey
Re: differential crush washer.....
Have you looked at any of the on-line resources like www.subaruparts.com ??
It's very easy to register, then look for oem parts, then SVX parts.
Glenn
Old 12-11-2008, 08:47 AM
Old Fogey
Which washer?
http://www.subaruparts.com/subaru.diag/2/i190-A.gif
Differential
01 $356.51 Gear set-hyp
02 $16.22 Pinion-diff bevel
03 $5.78 Wash-38.1x50xt t=0.95mm
$5.78 Wash-38.1x50xt t=1.00mm
$5.78 Wash-38.1x50xt t=1.05mm
04 $30.07 Gear-diff bevel
05 $37.27 Sft-axle drive
06 $0.23 Bolt
07 $0.53 Plate-ret lock
08 $30.00 Ret-diff side
09 $0.44 Circlip-inr29.8x2
10 $5.03 Oilseal-30x50x9 left hand
11 $54.78 Roll brg-40x80x19
12 $1.13 Bolt-10x39.5x15
13 $59.89 Case-diff left hand 1x- m/#358880-
$59.89 Case-diff left hand -1x
14 $13.72 Sft-pinion
15 $86.23 Case-diff right hand -2x
$86.23 Case-diff 2y-
16 $1.59 Str pin-5x40
17 $17.75 Gear-speedo-drv
18 $5.03 Oilseal-30x50x9 right hand
19 $3.82 O ring 84.5x2
Old 12-11-2008, 09:18 AM
taylorbr's Avatar
taylorbr taylorbr is offline
In Legacys all of the crush washers for the drain plugs are the same. No way in heck would I get it from the stealership, www.partsquick.com normally has them for something like 20 cents each, just get a huge bag for whenever you change your oil or tranny fluid.
'93 Legacy LS (will last longer than the cockroaches)
'94 SVX LSi
Old 12-11-2008, 09:37 AM
liamrh's Avatar
Isn't there a crush washer on the bottom of the differential oil drain where the bolt comes out?
Yes, I have searched the online resources, and will continue to look, but I am trying to find specific items and I bet someone has the part number somewhere.
Originally Posted by RojoRocket View Post
Which washer?
Differential
06 $0.23 Bolt
Old 12-11-2008, 10:30 AM
liamrh's Avatar
Check the attached pic, part number 11126aa000?
Old 12-11-2008, 10:37 AM
liamrh's Avatar
Originally posted by svxpert
I had a guy from NY come down last week for the exact same job. He wanted new hubs because his had 3 bearings changed through it already. I ordered the parts and pressed the bearing into the hubs before he came in. My prices were a little different than the Subaru dealers you got quoted. Here is a breakdown:
28411PA000: $109. >hubs
28411PA010: $109
28015AA070: $ 6.25 >seals
28015AA021: $ 8.15
28016PA010: $ 52.49 >bearings
SOA5165109: $4.15 >oil filter
11126AA000: $0.29 > crush washer
28044AA000: $2.50 > axle nuts
parts.......................................$344.3 2
labor 5 hours at $50/hr..........$250.00
total........................................$594. 32
now thats without the allignment, but I have a place I send people 4 miles away for $50.
Maybe this one? Same crush washer for the diff, trans, and oil plugs? Really?
Old 12-11-2008, 11:07 AM
liamrh's Avatar
11126aa000
Is the part number for the crush washer on the oil pan and trans plugs.
803926070
Is the part number for the crush washer on the diff plug.
Old 12-11-2008, 12:11 PM
taylorbr's Avatar
That second # comes up as a gasket, not a crush washer...
http://www.partsquick.com/ProductDetail.asp?i=143195
'94 SVX LSi
Old 10-16-2018, 06:27 AM
theflystyle's Avatar
Necro-bump...
Did searching but couldn't find a definitive answer. What are the part numbers for the rear crush washers? I think the front crush washer is 803926090 (correct me if I am wrong)
Using parts.subaru.com and other online part catalogs, I am only seeing the plugs but no washers (see the attached picture). This is the only thread I found to be related so forgive the old bump.
1994 SVX LSi
2008 Legacy 3.0R
Old 10-16-2018, 08:44 PM
Tireiron Tireiron is offline
There are no washers, they are NPT threads.
Old 10-17-2018, 04:27 AM
I learned something new today!
Thanks for the quick reply Tireiron
1994 SVX LSi
2008 Legacy 3.0R
