Old 12-09-2008, 03:35 PM
Re: Rubber trim on top of rear wheel well?
The part numbers are the same for all years and it was standard for all years.
The first 2 diagrams I posted were from the later sections (94-97). The last diagram was from the 1992 section.
Thanks for the diagrams. I personally like the diagrams at subaruparts.com for the 92 as they are a little easier to follow and more complete than the later ones. At least thats how i feel.
Old 12-09-2008, 04:25 PM
One of the reason I posted is because mine doesn't seem to be held in with screws, seems to be held in place with something that has a smooth plastic head on it. And as I mentioned the bumber cover seems to be over it in the rear and the side skirt over it in the front. Can this just be pulled out and put back in or do you need special tool? I don't want to damage anything, and I want to have a good idea of what I am doing before I order the parts.
NikFu: Yours look like they got Collagen injections.
Old 12-09-2008, 06:26 PM
What can I say, she is high maintenance.
Old 12-09-2008, 06:49 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Mine did not look like Nikfu. Mine was like SVXcess. There could have been two screws holding it as the parts list shows. It was coming off, so I just pulled on it slowly until it came out. No I did not replace them.
Old 12-09-2008, 07:18 PM
Old 12-12-2008, 05:39 AM
dcarrb dcarrb is offline
Originally Posted by Sean486 View Post
On my car they are pulling away in places towards the rear, just enough to not look right. I would like to replace them sometime in the future. Or even better, figure out a way to make them sit flush with the edge.
I'd look very carefully to see what's got the moulding "pulling away." First thing that went through my mind: Rust perforation. Hope I'm wrong.
dcb
Old 12-14-2008, 03:33 PM
dcb
Yeah, a little bit of rust worse on passenger side. I don't think it is tool bad overall, I'll have to get it checked out. For now I am just going to remove the old rubber and wait on replacing it until I know how to deal with the rust. I thought I read on here something about a rust inhibitor. I'll have to do some research. It doesn't surprise me though, the way that rubber was, it was sure to be catching moisture.
Old 12-15-2008, 05:51 AM
Sorry to be such a downer, but I suspect when you have it checked out you'll be told you're way past rust inhibitor. Good luck with it.
dcb
