Old 12-09-2008, 07:31 AM
Rubber trim on top of rear wheel well?
How do I remove that black rubber trim that is along the outer edge of the rear wheel well? The ones that sit up against the body.
On my car they are pulling away in places towards the rear, just enough to not look right. I would like to replace them sometime in the future. Or even better, figure out a way to make them sit flush with the edge.
From what I can tell it looks like it slips under the side skirt and rear bumper cover, but I'm not sure where they actually attach.
Any advice is appreciated. Thanks!
Old 12-09-2008, 08:00 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Re: Rubber trim on top of rear wheel well?
This was the first thing I did to my SVX. I believe you can pulled them off. Pull them in the same direction of wheel well curve slowly. Do this only if it comes off easily, if not wait for some more advise.
Old 12-09-2008, 08:03 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Anybody got a pic of what your talking about? I'm picturing my SVX and don't think I even have it, nor have I ever..
Old 12-09-2008, 09:24 AM
I'll try to post a picture of it when I get home.
Old 12-09-2008, 09:26 AM
Dannmarr,
Did you replace yours, or did you just leave it off?
Old 12-09-2008, 01:07 PM
kwren's Avatar
kwren kwren is offline
might try taking a couple of bolts out first?
Keith
Old 12-09-2008, 02:54 PM
Here is a close-up shot of my front fender well. See the thin strip of black rubber along the inner edge of the fender? It runs the entire edge of the metal fender only (not the bumper or the cladding)
The rear fender well looks the same. Here is the diagram
Here are the part numbers from subaruparts.com. Located in the Body Parts section under "mud guard".
59121PA001...Protector, front arch, right...42.90
59121PA011...Protector, front arch, left...42.90
59121PA020...Protector, rear arch, right...44.32
59121PA030...Protector, rear arch, left...44.32
Old 12-09-2008, 03:04 PM
One or two of mine are starting to peel away as well. I would be interested in any info on fixes.
Old 12-09-2008, 03:08 PM
Why would you remove it?
I don't think I have the thing in svxcess' picture.
Rear:
Old 12-09-2008, 03:18 PM
Nikfu- Yours looks much different as mine is identical to svxcess'
Old 12-09-2008, 03:21 PM
That's because mine are JDM tyte, yo.
Old 12-09-2008, 03:23 PM
Freeman's Avatar
Unregistered User
I don't even know if I have any... Was this standard on ALL svx's?
good point
Old 12-09-2008, 03:24 PM
I would think so as mine is a 92 and has it, svxcess' is a 96 and has it.
Old 12-09-2008, 03:31 PM
The part numbers are the same for all years and it was standard for all years.
The first 2 diagrams I posted were from the later sections (94-97). The last diagram was from the 1992 section.
