Old 06-26-2002, 02:46 PM
Green1995SVX
Legacy 2.2 Issue.
Quick non-svx question for y'all:
Car: 95 Legacy LS AWD 2.2L
Problem: You start the car and it immediatly dies unless you hold your foot on the gas for about 5 or 10 seconds while the car gets going.
Basically, you start up the car, and it runs for a split second then it dies.
any help would be great!
-Mike
Old 06-27-2002, 06:48 AM
svx_commuter's Avatar
I have a 91 L and I notice it will do that if sits for a long time. Maybe a week or so it has to sit.
After you get the car running is it okay? Does it start up the next day?
I think it may be from partly fouled injectors.
Old 06-27-2002, 01:47 PM
Mr. Pockets's Avatar
Moderator
Re: Legacy 2.2 Issue.
-Mike
Mike, my wife has a Legacy with the same engine. I have had a few problems with the idle air control valve. I suspect that in your case it may not be opening. It stays running with the throttle applied because then it doesn't need the IAC valve.
Mine was sticky. I took it out, cleaned it up with some carb cleaner, and had to do exactly the same a month or so later. It's been fine since then.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 06-27-2002, 09:59 PM
subymtnguy's Avatar
subymtnguy subymtnguy is offline
"high" in Colorado
Legacy 2.2
I have a legacy 2.2 also.....
try a can of BG fuel system cleaner; kind of steep ($20 a can) but does wonders with injectors and the fuel system.
could be a cheap fix....
92 Liquid Silver LSL
85 BRAT GL
81 280ZX
91 Legacy wagon
86 Pontiac Parisenne (55k)
86 Kawasaki ZG 1000 Concours
81 KZ 1000 LTD (shaft)
