Old 05-30-2002, 06:38 PM
Question Streering wheel removal
Has anyone ever removed their streering wheel? Is it a major job? I would think that it is a little tricky because of the air bag. I am concidering having my wheel redone. Any information would be appreciated.
Old 05-30-2002, 09:47 PM
vkykam's Avatar
vkykam vkykam is offline
The Road Less Traveled
Re: Streering wheel removal
Remind me after the weekend, as I'll have to remove it to replace the combination switch.
VK
Old 05-30-2002, 10:29 PM
nordique14's Avatar
Who watches the watchmen?
removing the steering wheel
It's not that hard. If I can do it, almost anybody can. Here's the details of my experience.
Before you start, get a Torx Security bit set. I think the bit size you need is either TX-30 or TX-40 (I can't remember). The difference between a regular Torx bit and a Torx security bit is that the security bit has a little hole in the center.
Before you remove the steering wheel, make sure that the front wheels are compeltely straight ahead before you start. That will make it much easier when you put the steering wheel back on.
The airbag deploys via electrical current. So you will need to disconnect the battery. Disconnect the negative side of the battery and let it sit for 15 mintues to fully drain the charge. DO NOT SKIP THIS STEP unless the possibility of an airbag blowing up in your face thrills you.
Remove the plastic covers on either side of the steering wheel. Now you will use the Torx security bit to remove the airbag. If I remember correctly, there are 2 screws on each side. Once you have removed them, the airbag should be loose. Gently pull off the airbag (the center part of the steering wheel). It will be attached to the steering wheel via a wiring harness. The harness wiring is not that long, so don't pull it out too far. You should now be able to unclip the harness. Note that before you start handling the airbag, it's best to touch a grounded part of the car. Also, do not put the airbag on anything that might generate any static electricity (such as a plastic bag).
Once you have removed the airbag, you will need to need to remove a center nut before you can remove the steering wheel (I can't remember the size of the nut, but it's a big one). The nut comes off easy, but the steering wheel will take a few tugs to loosen up. Once it's loose, it can be pulled right off. The removal part is now complete.
Before you put the put the steering wheel back on, line up the hub by following the directions on hub. If you don't, your steering wheel will not point the same directions as the wheels.
Now reconnect your wiring harness on the airbag. Same rules apply about avoiding static electricity. Put the torx screws back in. Replace the plastic covers. Reconnect the battery. Start the car. Look at the dash for the airbg light. When you start the car, it should stay on for about 10 seconds and then go out. If it stays on, you didn't reconnect the airbag properly. Take the car for a drive and make sure the steering wheel is lined at the top when you are going in a straight line.
All done.
Good luck,
Old 05-30-2002, 11:38 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Just a couple insights.... don't take the center nut completely off, just loosen it a couple threads, that way it won't pop you in the mug when it comes loose. Actually you should use a puller to remove the wheel. Before removing the wheel, use a nail or similar to scratch a mark on the wheel hub and the column shaft for re-installation alignment.
Old 05-31-2002, 05:01 AM
svx_commuter's Avatar
I haven't done this yet But I do remember seeing a lot of warnings about handling the air bag and where to place it when it is out of the car. It should be placed bag side UP so that it does not launch if the bag goes off. How it could deploy with no electricity I have no idea. Static electricity?
Old 05-31-2002, 05:52 AM
Never2phat Never2phat is offline
Post Word of caution
Another word of caution..........
When removing your air bag do it standing off to the side, NOT sitting in front of it. If it was to deploy your less likely to get hurt
B.C.
Old 06-16-2007, 03:41 PM
michael's Avatar
michael michael is offline
What Potholes ???
Just thought I'd fill in a gap. The size of the the security torx for removing the airbag is T30.
Wanted: Steering Wheel
Old 06-16-2007, 03:44 PM
Thanks. I will try to do a How-To on it. That will help.
Old 06-16-2007, 04:02 PM
michael's Avatar
What Potholes ???
This may help, just add to the description that it's a T30 torx.
Old 06-17-2007, 07:48 AM
DarknessofDeath's Avatar
Inhabitant of Darkness
i thought there was a how to document on removing the steering wheel?
if it's not here maybe it was at information warehouse
Old 06-17-2007, 02:32 PM
now that i had time to think about it...no it must be something else that i was thinking of
Old 06-17-2007, 10:05 PM
There was one on airbag removal. I will look for it and try to link it for you.
Old 06-19-2007, 03:53 PM
I hate security bolts...completely unnecessary.
