funky smell
when i turn on the a/c then turn it off after a while. this smell come out of the vent, and haunts me. is there a cure for this problem
white leathers, h.i.d, ecutune S/C stage 4, 14 inch 2piece rotors big brake kit., , msd ignition, c/f dash kit, front spoiler,carbon fiber jdm rearc wing,19 inch rims, nos, , aem fuel regulater, koni-gc package, ported cylinder heads, supercharger cams,solid buck and shims,wrx sti intake valve and exhaust valves,& valve springs, gas analizer,water injection, exhaust temp gauge, idiglo gauges, shift kit, , remote start, all automatic windows,2.5 inch true dual exhaust system with crossover, and 2 borla stainless steal muffler,air filter velocity air stack 3inch to 6 for air filtre, group n mounts, momo steering wheel, dyno will happan soon |
It might be mold or something in there. On a hot day turn the heat on as high as it will go (econ) and leave it for an hour or two. That's what someone suggested..
Yeah, you've got dead ghosts in there, alright. I'd try some spirits of turpentine sprayed into the vents.
Works for me. Ron.
Good s**t happened. 69 was worth the wait. '92 stock semi-pristine ebony - 160K '96 Grand Caravan - 240K '01 Miata SE - 79K '07 Chrysler Pacifica - 60k - future money pit. |
I don't know about turpentine, but a can (or two) of lysol in the intake vents helped to get rid of the wet sock smell in my AC. I think I alternated between high heat, vent, and cold for about 10-15 minutes each. The lysol smell will persist for weeks if not months, so choose your fragrance carefully.
KuoH |
If you can get underneath your car look for the a/c drain on the right side floorboard near the bellhousing. Make sure it is clear and unobstructed. Usually the drain collects debris (leaves, etc.) and doesn't drain properly. Sometimes the condensate from the a/c collects so much that it leaks from the a/c case and soaks the passenger carpet and pad - another place for mold and mildew to flourish. Look up under the glove box and pull the carpet towards you a tad to see if the backside is damp. If so you'll need to pull it up and air it out, maybe use a fan and some mildew killer. Make sure you find the source of the problem so it doesn't repeat itself.
Floor board?
[QUOTE]Originally posted by Beav
[B]If you can get underneath your car look for the a/c drain on the right side floorboard near the bellhousing. A Beav Thats a bit dating, I have not heard them called that since the 30s when there were boards. Harvey.
Re: Floor board?
[QUOTE]Originally posted by oab_au
[B] Quote:
Ron.
Re: Re: Floor board?
Uhh....kinda. Have you seen what's under the RF carpet pf a 928? A hunk of marine plywood covering the most catastrophic fuse and relay center you've ever seen in a car.
Actually 'floorboard' is a colloquial word here, entirely interchangeable with 'floor'. And I still say 'groovy' once in a while...
Re: Re: Re: Floor board?
Hrummpf. Ron.
autozone
sells this small can of Ozium stuff you can spray under the dash
thru the a/c vents and cores.......helps eliminate odors too..... and like they mentioned earlier......check the drain that exits under the car...dg
My mom will forever live in me and never be forgotten, one day Ill see her again CLICK the LINK below to Visit the SVX Store: http://www.planetsvx.com http://www.motorsportwarehouse.com/svx/sig2.jpg Cars in the garage: 92 Toyota Soarer Single Turbo JDM RHD 70 Boss 302 Mustang 39k original miles 97 SVX Lsi 92 Liquid Silver Murano-ized (1st of its kind) 71 Cougar Xr7 Conv 351c 4v 4spd 69 SS Camaro 350 71 Nissan RHD Fairlady Z 70 Stang Fastback 70 Amc AMX 390 71 240z 89 Conquest TSi w/ 5.0 v8 swap 84 Mustang GT Turbo conv "good, if it bleeds, we can kill it ....." |
Re: Re: Re: Re: Floor board?
In Oz more important things are done with the right hand. like giving the fingers to other drivers. In my case being completely left handed I have to open the roof and use the digits that way, otherwise I find the left hand shift very handy. , don't know about the other 90%. Just as well I live in Australia. Harvey. lefthanded as usual.
