Old 12-10-2007, 03:17 PM
SubaruSVXCrazy's Avatar
SubaruSVXCrazy SubaruSVXCrazy is offline
AWD..... NOTHING COMES CLOSE
Send a message via AIM to SubaruSVXCrazy
Fuse Box Questions
Question 1:
I heard that in an Outback that you can pull a fuse that can disengage the rear wheels and just make it front wheel drive. Can you do that with the SVX?
Queston 2:
I was looking at the fuse box and I noticed that on it, it said (Seat Heater). Did they have heated seats in any other countrys or did they use the same box in a different model?
1992 Subaru SVX LS-L #5045 Dark Teal
1992 Subaru Loyale Wagon Gray (SOLD)
1999 Subaru Impreza 2.5RS Coupe Black Ruby (SOLD)
1969 Subaru 360 Deluxe Ivory White
2005 Subaru Impreza WRX STi World Rally Blue
1993 Subaru Legacy L Wagon Teal Metallic (SOLD)
1998 Subaru Impreza 2.5RS Coupe Rally Blue Pearl
[SIGPIC][/SIGPIC]
Old 12-10-2007, 03:25 PM
1 Yes, in the fuse box under the hood by the battery, there is a slot labled "FWD" if you put a 10 amp fuse in that spot it will "Diss-engage" the rear transfer clutchs that drive the rear diff.
2.yes, seat heaters were available in other contrys...including Canada, but not in the USA
Old 12-10-2007, 04:06 PM
Thanks alot!
[SIGPIC][/SIGPIC]
Old 12-10-2007, 04:51 PM
JaySVX's Avatar
JaySVX JaySVX is offline
If you look in the outback by the back of the engine bay on the passanger side, there's a FWD pocket for a fuse that disables the AWD making it FWD only. Similarly, the SVX has one in the fuse box under the engine. It's located in the front next to the AC fuse. If you install it, CHECK CAREFULLY when you go to remove it, as if you remove the AC fuse on accident, it will prevent your radiator fans from turning on, your car will overheat, possibly causing engine damage, or in my case, simply blowing the radiator, causing there to be an ERUPTION of water flooding out from your hood in all directions. In my case, it shot out both sides of the car under the hood about 4 feet, getting both the cars next to me nice and wet.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 12-10-2007, 05:17 PM
Strife's Avatar
Strife Strife is offline
How do you tell if you have heated seats or not?
Where would controls be?
1992 Subaru SVX
1983 Pontiac TransAm
1986 Kawasaki Ninja 600
1991 Eagle Talon TSI AWD
Old 12-10-2007, 05:20 PM
redlightningsvx's Avatar
Collision Refinishing Tech
if im not mistaken either by the window switch or in the coin holder spot
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
