Old 12-22-2007, 10:41 PM
svxash's Avatar
svxash svxash is offline
Even if it did open in the boiling water, like benebob stated if there is an air pocket on the other side of the t-stat it won't open.
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3
Old 12-22-2007, 10:45 PM
Next time you refill with coolant try this;
Mix up 2 gallons of 50/50 mix into 2 - 1 gallon containers.
Remove the top rad hose from the radiator and add about one gallon into the engine through that hose. If it overflows before you use up the gallon, that's fine, put the hose back on.
Add the rest into the radiator. I think the actual capacity is 1.8 gallons, so you will have some left over.
This gets fluid throughout the system immediately without waiting for it to get through the "jiggle hole". You'll still want to run it with the cap off and add until the air is gone.
Old 12-23-2007, 12:39 AM
I am going to replace my radiator in the next couple of days too. I will give that a try. Sounds like a good way of doing it. Thanks
Old 12-23-2007, 05:58 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Thanks for the advice guys... I will give it a try after the holiday.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 12-23-2007, 08:31 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Originally Posted by TE1221 View Post
The Stant Thermostat does have the jiggle pin. It's weird because I boiled in a pot before I installed it and saw that it did fully open at 180 degrees.
It just stinks because the car was sitting since thanksgiving and it's one thing after another. I got a code 11 and 21 today but got rid of it by cleaning the carbon deposits off the crank sensor.
I'll just wait until I can get the OEM one. luckily the car is no longer a daily driver.
Weird, as the Stant I bought from Advance Auto didn't have the jiggle pin I did the "OT mod" and drilled two small holes through the stat. Takes slightly longer to come up to temp now.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 12-29-2007, 04:06 PM
Tim's Avatar
Tim Tim is offline
Bwhahaha... it worked! I can finally drive her again . All the air pockets finally came out. I repalced the radiator cap with a new one and so far no leaks. The water temp sensor issue i've been having is on and off, but I will be ordering a new one this week.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
