Old 11-18-2007, 08:33 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Silla radiator update... and not a good one
For some reason I always seem to be experiencing some sort of coolant leakage everytime the season changes, whether its the hoses leaking or something to that extent.
This time I kept noticing coolant spilling through the radiator cap. I replaced the radiator cap but it did it again. I checked and blew out the overflow hose. I then checked the Fsm and diagnosed it as a bad thermostat. I replaced that and the problem went away.
Today I drove the car and now the radiator seems be leaking where the plastic tank meets the metal grates of the radiator.
The car never overheated, but I feel that the sillas should be a tad more durable than to fail under this kind of condition? It was almost 3 months old. I think Im going to see what I can do as far as replacing it.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 11-18-2007, 08:44 AM
I would check back with the company that you bought it from. I would think that it may be a problem with that one. I have not heard negative things about them until now. As a matter of fact, I just bought a similar one yesterday.
Old 11-18-2007, 10:56 AM
svxash's Avatar
svxash svxash is offline
I have a Silla in our Land Rover and I've never had any problems with it.
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3
Old 11-18-2007, 11:38 AM
Wikedjuggalo's Avatar
Rebuilding
I have one in my SVX I believe. Haven't had a problem with it. Hope you get everything going good. Also maybe the shipping company dropped it or something and damaged it.
Old 11-19-2007, 01:24 PM
Tim's Avatar
Tim Tim is offline
I drove it again and I can't seem to find where the leak is up top. It seems to behave the same way as it did before.
The autozone and the pepboys thermostat seem to be much smaller in depth than the Subaru OEM one. Should that make a difference? The actual diameter of the thermostat is the same as the OEM.
Is everyone using the OEM one?
I just brought my original thermostat that I took out to 180 degrees and it still would not open. I went even higher to boiling but the thermostat did not open. I know that the one i took out is bad, but now i'm not sure if the replacement is bad or if its insufficient in size.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 11-19-2007, 01:47 PM
siceclipse's Avatar
siceclipse siceclipse is offline
T-Stats are man made mechanical devices that CAN fail brand new out of the box.
So its not all that crazy that the new t-stat doesnt open.
Mike
1992 SVX LS-L Pearl White 102,000 miles (Gone)
2005 Evolution 8 SSL Tarmac Black (new daily)
1995 Eclipse GSX Durango Copper Pearl (teh beast)
276awhp/280awtq @ 18psi (560's inj)
260awhp/260awtq @ 17psi (stock inj)
Old 11-19-2007, 01:54 PM
Tim's Avatar
Tim Tim is offline
After warming up the car, the bottom hose still continues to be cold while the top is hot. The day before I drove the car pretty hard after replacing it without any issues. I hope that's what it is
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 12-11-2007, 07:13 AM
Tim's Avatar
Tim Tim is offline
I just wanted to give an update to everyone.
The 3rd thermostat was tested to open all the way and the 2nd thermostat replacement was bad. The original Subaru one was bad also.
After replacing it the radiator stopped leaking out of the cap, but now leaked out of the seams were the plastic tank meets the aluminum grates of the radiator.
I called up Radiators US, the store I bought it from off Ebay. The silla radiators have an lifetime warranty for normal wear and tear issues.
They offered me 2 options. I can pay 170 dollars for a new one to ship out, then I return the old one and they will credit me back, or I can send the old one out first and not get charged.
My new radiator should get here this week. Right now the SVX is sitting in the garage.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 12-11-2007, 08:28 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Tim, go spend the extra $4 and get a Subaru t-stat. For whatever reason aftermarket stants and the like and subarus just don't go together well over the long hall. Cracked heads or blow gaskets cost much more than $4 every 100k or so.
Old 12-11-2007, 08:55 AM
Tim's Avatar
Tim Tim is offline
Thanks for the advice. I will go order one once I clear up my school term bill
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 12-22-2007, 03:48 PM
Tim's Avatar
Tim Tim is offline
Update again... I finally got the radiator after it got delivered to the wrong house (had to go there to get it). I replaced the radiator now and put everything back together. It still leaks out from the cap.
Bottom hose is cold, while the top radiator tank and upper hose is very hot. Blah...
I'm just going to call Liberty Subaru this week and order an OEM radiator cap, thermostat and gasket.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 12-22-2007, 06:11 PM
benebob's Avatar
Tim you did properly bleed the system on filling with coolant right? Run with no cap until the t-stat opens with your heat on. You have the t stat facing the right way with the nipple pointing the right way? Sounds to me like the t stat isn't opening which means its bad or it simply doesn't have any fluid behind it. Air won't make a t-stat open. That's all I can think of at the moment.
Old 12-22-2007, 08:18 PM
Tim's Avatar
Tim Tim is offline
I ran the car for about 20 minutes until all the bubbles were worked out. I did not however turn the heat on.
the aftermarket tstats from autozone are the same diameter as the subaru oem, but the subaru is bigger and beefier. should that make a difference?
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 12-22-2007, 08:32 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Tim,
Everything that Ben said + note that the Subaru-supplied T-stats have a small hole with a "jiggle pin" (yeah, that's a technical term) that allows air bubbles to escape when you're filling the system, while aftermarket T-stats don't. The lower hose not getting warm does point to the T-stat not opening up.
I wouldn't give up on the radiator just yet.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 12-22-2007, 09:13 PM
Tim's Avatar
Tim Tim is offline
The Stant Thermostat does have the jiggle pin. It's weird because I boiled in a pot before I installed it and saw that it did fully open at 180 degrees.
It just stinks because the car was sitting since thanksgiving and it's one thing after another. I got a code 11 and 21 today but got rid of it by cleaning the carbon deposits off the crank sensor.
I'll just wait until I can get the OEM one. luckily the car is no longer a daily driver.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
