Old 11-14-2007, 05:53 AM
CorSVXette's Avatar
Classic SVX
Gps
Does anyone know of a portable GPS that works with our cars? I know there is something in our front windshield that does not allow the "e-zpass" to work and I think it also does not allow my 2 (two) portable GPS's to work either. They don't seem to be able to pick up a sattelite signal through that windshield. I have a Garmin (model 300? I think) and the Finedrive 400. Does anyone know of a brand/model that does work?
Paul
1969 Corvette
1995 Corolla
2003 Highlander
Old 11-14-2007, 06:10 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
I have the Garmin C330 and the C340 successor. Both work in the front windshield under normal conditions. Sometimes it can take up to 5 to 10 minutes before the unit will be ready to navigate.
However, when going into the city, it loses reception pretty fast in between buildings. I Notice that the windshield causes the GPS to lose communication with a few of the satellites, because the signal strength indicator lowers by 1-2 bars when placed there.
A solution might be able to purchase the external antenna lead that you can run toward the back windows. This would allow your GPS to function the way it should.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 11-14-2007, 06:28 AM
CorSVXette's Avatar
Classic SVX
Do you put it on a certain spot of your winshield? I think I have the 330 and I usually put it on the left side of the windshiled. I had them both on the other day and drove around for over 30 minutes and got no reception. I noticed that if I took it off the windshield and held it in my hand near the side window I got reception, but I cannot drive around like that. Where on the window do you put it? Maybe I will have to look into that antenna adapter.
Paul
1969 Corvette
1995 Corolla
2003 Highlander
Old 11-14-2007, 06:36 AM
Tim's Avatar
Tim Tim is offline
I keep mine set above the front drivers side tweeter. Are you driving in the actual new york city area? I noticed that my GPS just stops working when I'm in between the building because there aren't enough satellites to communicate with through the windshield and between the building. All of my suburb traveling and rural areas have not problems though.
You may need the GPS that has the newer processors that are designed to work better to communicate between buildings.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 11-14-2007, 08:25 AM
Mr. Pockets's Avatar
Moderator
Paul, can either of your GPS receivers use external antennas? I don't really use my GPS any more, but I have an external antenna in my trunk. I just tucked it inside the liner on the trunk lid. I got fantastic signal strength from there and had a position lock in seconds every time I turned it on.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 11-14-2007, 08:28 AM
I was wondering how that would work??? I was thinking about putting my sirius antenna in the trunk to hide it. I thought it might work well through the fiberglass.
Old 11-14-2007, 09:02 AM
Moderator
It worked really well, actually. I haven't tried my Sirius antenna yet. I don't drive the SVX much, so that radio doesn't get mounted in there that often.
Sirius is awesome, though.
2005 Outback
END OF LINE
Old 11-14-2007, 09:09 AM
shotgunslade's Avatar
My Garmin Nuvi 650 works just fine in the car. It does take 5 minutes or so to find the satellites when I turn it on. Sometimes, I just take it off the mount and hold it out the window to speed up the process. The place where it really gets mixed up is in areas with multiple closely linked freeway paths, especially around the GW bridge, the Hutch, Cross Bronx, etc. It can't tell which ramp you are on. I don't know if the radio opacity of the SVX windshield reduces the accuracy of its location, so that it can't tell exactly which of the stacked highways you're on.
Old 11-14-2007, 09:27 AM
mikecg's Avatar
mikecg mikecg is offline
Do your GPS units have an option for an extrnal antenna. It might be a cheaper option than buying a whole new unit. I have a unit that hooks to my laptop and I run the antenna cable out my passenger door.
Old 11-14-2007, 04:49 PM
CorSVXette's Avatar
Classic SVX
OK Thanks. I will see if I can get an external antenna for the systems I have. let me ask you though, did you have the run a cable/wire from the unit to the back of the car where you have your external antenna?
Paul
1969 Corvette
1995 Corolla
2003 Highlander
Old 11-16-2007, 10:32 AM
Nick_C's Avatar
Nick_C Nick_C is offline
My TOMTOM ONE works perfectly mounted on the inside of the windshield
Nick
Former:
1987.5 XT Turbo GL-10
1988 XT6
1996 SVX LSi AWD
Old 11-16-2007, 10:53 AM
Moderator
Of course, but it was a piece of cake. I just tucked the wire in between the passenger seat and the center console, under the right-rear floor mat, tucked it in between the right rear seat and the armrest, through to the trunk and then up under the trunk lid liner. I didn't attach it in any way to anything, besides the double-sided tape I used to stick it to the underside of the trunk lid.
The wire wasn't perfectly concealed, but I used the trunk for luggage a lot back then, and it was never in the way.
2005 Outback
END OF LINE
Old 11-16-2007, 11:35 AM
this thread reminded me that my Garmin C330's battery was dead, so i searched around to look for battery replacement how-to's.
found some info how to do it cheaply without sending it back to Garmin, and then i saw a post about removing the bezel and hitting the reset button - now it works! it used to stay on for a minute or two and then shut off, but i just now had it on for a good 20 minutes.
just a heads-up for anyone with a Garmin and battery trouble.
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 11-16-2007, 01:07 PM
Speedklix's Avatar
Locker Link Solution
our street pilot with an ext ant would not work in the SVX. I tried it in SickSubie's, the only way to get a signal was to put it all the way to the pillar. I think it was the first time I used it in an SVX, so it shouldn't have just been a fluke.
I would go the external ant idea if it is also a remote one (like with a cord), my external ant for gps is on the the turnk. I have one for gps and one for xm on opposite sides, looks like hinges until you see the little xm logo on one
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 11-16-2007, 01:26 PM
Bizarre Bizarre is offline
Send a message via AIM to Bizarre Send a message via Yahoo to Bizarre Send a message via Skype™ to Bizarre
Nextel
I have Nextel with Telenavtrak for work.
Works OK provided antenna points straight up. Titanium Oxide in the windshield will block most transmissions.
'95 SVX LSI Black, just wire mod.
New speakers + homemade front mounts.
"In times of peace, a gentleman keeps his sword at his side." Sun Tzu c 300 b.c.
