Old 05-03-2002, 06:19 AM
UStifosi
What type/brand of coolant
should I be using? I am new to the SVX world. I know certain Honda's call for special blends.
Old 05-03-2002, 09:43 AM
lee lee is offline
coolant
there's lots of brands - just make sure it says it's silicate free. The old style antifreeze had silicants in there that were tough on water pump seals (You can think of it like tiny grains of sand). Changing the water pump is a major job on the SVX, best done when its time for a timing belt change since that has to come off first anyway.
Old 08-05-2009, 05:54 PM
michael's Avatar
michael michael is offline
What Potholes ???
Re: What type/brand of coolant
This thread was found using a search and had an appropriate name. It is old and I would like to fill it with some more detailed info. What coolant is the majority of SVX owners using? I have an old bottle of peak in the garage that I'm not sure if I should use.
Wanted: Steering Wheel
Old 08-05-2009, 06:00 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
I use the Prestone, its now advertised as long-life and "mix with any type of coolant". Ive been running the car in stop and go in 110 degree heat here in the high desert on my A1 Cardone waterpump...so far so good.
Old 08-05-2009, 06:12 PM
redlightningsvx's Avatar
Collision Refinishing Tech
I only use Subaru long life coolant since I get it free at work
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 08-05-2009, 06:23 PM
NiftySVX NiftySVX is offline
why bother, just use the subaru stuff, mix with distilled water.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 08-05-2009, 06:47 PM
michael's Avatar
What Potholes ???
I just wanted to know if the subaru stuff was worth it. They do sell cooling system conditioner after all. For the life of my SVX I have been using Prestone, the peak was purchased for my Rabbit. Tomorrow I'll have to show you Subaru's new and improved thermostat.
Old 08-05-2009, 11:11 PM
I use SIERRA pg http://www.sierraantifreeze.com/ from Old World Industries, Inc
from http://www.zrxoa.org/forums/showthread.php?t=97351
I checked with Sierra and they say their coolant contains 250ppm of silicates. How does that compare to Engine Ice, LowTox or Honda's coolant.
FYI, this is a statement from Sierra/Peak:
"The Kawasaki is an Asian manufactured motorcycle and requires a Silicate
free antifreeze. I would recommend installing our PEAK GLOBAL ANTIFREEZE
which is Silicate free.
PEAK Tech Dept."
and more reading http://choppercharles.com/cs/forums/3821/ShowPost.aspx
http://www.tractorsupply.com/automot...oolant-0836045 have been using it for years
and for our four-legged friends http://www.beaglesunlimited.com/beag...epoisoning.htm
