Old 01-29-2007, 05:14 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Improving performance on my....
rear defroster?
When I first got my car, all the ice on the rear windshield would melt off easily but as the years go by it takes longer and longer for the ice to melt off.
With today's snow the ice took about a good 20 minutes before it would really melt off, but that was after scraping away most of it. It seems like the center of the windshield melts ice the best while the outside starts to fade in effectiveness.
Is there anything we can do to revive the rear defroster?
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 01-29-2007, 05:41 PM
There is nothing you can do in respect of the actual element imbedded within the glass and it would be unusual for this to fail. The elements run crosswise, so that an open circuit in one, would result in a vertical gap in the heated area, not at the sides.
You should carefully check all connections and measure the voltage at the connectors closest to the glass, with the element energised so that any voltage drop/loss will be apparent. If you are not recording say eleven volts or more with no engine running, you will have to investigate further. As you have noticed a deterioration of late, a faulty connection is likely.
Old 01-30-2007, 06:05 AM
Tim's Avatar
Tim Tim is offline
Thanks Trevor... do you know if there is a wiring schematic somewhere?
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 01-30-2007, 01:47 PM
I have one for my JDM model but it shows little that will assist you. Finding the closest connection to the element is your first step. There are usually tabs on the glass with push on connectors. Be careful here and don't break them.
It is a good idea to sharpen the points on your meter probes to get to the actual tabs on the glass so as to prove the last point in the circuit. Blunt points can allow you to be fooled by paint, dirt, rust or corrosion.
Old 01-30-2007, 02:33 PM
light the car on fire before you get in it... you know, just to warm it up
Old 01-30-2007, 06:41 PM
Tim's Avatar
Tim Tim is offline
I could light the oil stain on my driveway to get it cookin' :P.... I think im looking at mid february... do you have any new projects coming up Tom?
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 01-30-2007, 07:03 PM
not that I know of... I you want, you can drop it off sooner than that and take my teal until you can get back
Old 01-30-2007, 07:25 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
why does every thing around you have to blow up?
- John
Old 01-30-2007, 07:33 PM
Tim's Avatar
Tim Tim is offline
Actually... if we can do that I can come up anytime then. Maybe we can do something like drop it off on like a thursday night or friday night and then come back whenever it's finished. Let me know ...
How would you get around though? Is your silver fully operational?
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
