Old 01-21-2007, 12:19 PM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
sti wheels on an svx
I recall only certain year sti wheels will fit our cars..? I wouldn't mind having some goldies on my silver, I think it would look pretty good. I have a 92 if that matters.
Brian
Old 01-21-2007, 12:23 PM
Darren's Avatar
Darren Darren is offline
Hi,
Version 9 Impreza wheels 05 onwards have the same PCD, not sure about hub size & offset.
Darren
Old 01-21-2007, 12:24 PM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
05-07 STi Wheels will work. They fit perfectly, my track wheels are STi BBSs wrapped in Toyo RA1s.
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
Check My New Homepage..
Old 01-21-2007, 12:40 PM
Ricochet's Avatar
I brought some ham.
Okay thanks. I dug around and found the 04's had a 5x100 bolt pattern, 05's and up were 114.
Brian
Old 01-21-2007, 12:45 PM
gest24's Avatar
#1 6MT In Cali
No problem. THe only thing I noticed, they're a little heavier than my Fliks. But they're stronger because of the forging. Either way, they fit 10x better than any aftermarket wheel, no hub sentric rings needed. What kind of tires do you plan on running?
RIP
84 VW Scirocco
02 WRX
Old 01-21-2007, 01:00 PM
Ricochet's Avatar
I brought some ham.
not sure, some summer-only ones.. maybe S03's or azeni's. I come home in August so I've got time to dig around.
Brian
Old 01-21-2007, 01:28 PM
maybe its because the flix were 7" wide and the BBS are 8??
Old 01-21-2007, 03:49 PM
gest24's Avatar
#1 6MT In Cali
Yeah, I forgot about that tib bit of info. Either way the BBSs are a better wheel.
If you buy a set with the RE070s you'll have a great tire. I've had 2 sets now and beat them on the autoX course and then Daily Drove them and were great tires.
RIP
84 VW Scirocco
02 WRX
Old 01-22-2007, 02:40 PM
cdigerlando cdigerlando is offline
Aftermarket
Looked at rim options at Tire rack. They have a nice Graham light rim (only 15.5 lbs). 17x8.5 w/ +40 mm offset. Mold form forged. 490 ea. Would these work? Lots of options out there now that the STI is compatible.
Chuck D.
1992 Subaru SVX LS-L - Heavily modded turbo
2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods
Old 01-25-2007, 04:54 PM
curly2k3's Avatar
curly2k3 curly2k3 is offline
Own'eded
Send a message via AIM to curly2k3 Send a message via MSN to curly2k3
i loved having the gold BBS's on my pearlie... but i sold my set when i bought the Impreza all 5 for 1k, with RE070's... maybe i will get another set when iu get more cash again
98 Impreza Wago-O-Doom & Datsun Roadsters
