Old 01-18-2007, 03:38 PM
etz bseder etz bseder is offline
Rear wiper
I need a little help. My rear wiper fluid doesn't spray, but i can hear the motor try. does anyone have any ideas that would help me get it working>
'92 LS-L, exhaust, intake, audio, ecu 1V4?, hyper ground kit.
Next changes ... PAINT, fix engine problems, 4.44. (GONE)
'97 Impreza Outback Sport, magnaflow muffler, cold air intake, Alpine Type S, MP3/iPod deck, NGK wires, etc.(GONE)
Old 01-18-2007, 04:02 PM
Is the jet blocked? This is a common problem. To clear it will require a very fine needle or whatever. Presume the container is full! Check that the thin hose is not folded at some point. If you can get at the back of the jet, remove the hose/tubing and see if it flows and is clear at that point. All fairly obvious stuff.
Old 01-18-2007, 11:32 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
trace the tubing and check fluid level
- John
Old 01-19-2007, 06:07 AM
dcarrb dcarrb is offline
I've had to replace the fitting at the base of the wiper to which the tubing attaches, because the attach point had snapped-off. If that's the case with yours, you'll have washer fluid dripping from the trunk liner panel beneath the wiper.
dcb
Old 05-30-2007, 08:34 PM
I've also had the hose kink on me and not let any fluid pass through.
Old 05-30-2007, 09:50 PM
I had the same problem with the fitting that broke off and water dripped out of the cover. I replaced it and it works fine now.
One other didn't work, and when I put more fluid in it, it work ok again.
