Old 01-15-2007, 11:49 AM
Sybaris Sybaris is offline
Question Tranny Fluid Level
Drained the fluid from the plug on the bottom. Got about 6 quarts out.
I've put 4 quarts back in and the stick already says it's full if it was hot.
Has the fluid just not cycled through?
Should I run her for a minute or so then check the level?
1997 Bordeaux Pearl LSi ~45K
Old 01-15-2007, 11:58 AM
Sov13t's Avatar
Sov13t Sov13t is offline
Yeap, run the car and even take it for a spin around the block.
Then return to level surface and check the stick again, add/remove fluid as necessary.
-Sov.
Old 01-15-2007, 01:45 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
dont drive it around the block thats asking for trouble.... just make sure the car is on a level surface and cycle the shifter through all the gears a cuple of times... and wait a few min because fulid left on the tube from the fill is prob. giving you a false reading
- John
Old 01-15-2007, 02:25 PM
Thanks
Ran it a few seconds and ended up having to put in about 3/4 of a quart.
