Old 01-10-2007, 11:25 AM
PaulSVX's Avatar
PaulSVX PaulSVX is offline
Tranny compatibility
Do you have a tranny compatibility list for SVX ?
preferable year and models of the car.
1992 Pearl White SVX LS-L
1991 "Red Baron" Grand Prix GTP 5spd
2002 Chevy TrailBlazer LT
Old 05-30-2007, 05:15 PM
No answers?
Basically '98 and older transmissions without the spin on filter will work with the SVX.
Most Subaru manual transmissions are SVX compatable.
Old 05-30-2007, 08:01 PM
JaySVX's Avatar
JaySVX JaySVX is offline
Keep in mind that is with modification.
I believe they were saying that the 05+ sti 6speed tranny is compatible, 99-2005 wrx is compatible, 94-99 legacy is compatible, and some era of the forester. My years are wrong probably but they should be close, perhaps someone can clarify...
Keep in mind though, these all require modification including fabricated parts, fitting, etc, but quite a few folks have converted to manual trans, think there's around 50 on the network with a 5speed or 6speed.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 06-12-2007, 07:45 PM
I was referring to just bolting to the engine/wiring.
Old 06-25-2007, 02:04 PM
paulmeisterpk's Avatar
paulmeisterpk paulmeisterpk is offline
Sconnie
Send a message via MSN to paulmeisterpk
Sorry for being a noob, but will any 98-older 4EAT tranny bolt in and work? I'm not looking for all the work of a manual swap and I'm looking at a car with a bad trans. Thanks.
Old 06-25-2007, 02:15 PM
Yeah, any trans will work and bolt up, but the SVX has a final drive ratio in the front and rear diff that is different than all other automatic Soobs. You'll need to match the rear diff to the new trans.
Old 06-25-2007, 05:34 PM
Sconnie
So I will have to replace the rear diff too?
Old 06-25-2007, 06:08 PM
svxaddict svxaddict is offline
Yeap
use the rear diff from the trans you buy.
it will usaully be 4.11 or 4.44
i have done these transmission swaps for about two years. about 20 swaps
Yeap
Old 06-25-2007, 06:09 PM
Talking Yeap
including about 5 manual swap and 1 rwd wrx manual swap.
Old 06-25-2007, 06:28 PM
Sconnie
So will I be able to use the SVX's axle shafts with the different rear diff?
Old 06-25-2007, 06:38 PM
easy trick
one axle on the svx has a longer tip i got a grinder and chopped off the extra tip and wala, still drivin it
Old 06-25-2007, 06:52 PM
If you just directly swap the new diff for the SVX diff, you'll most likely lose the LSD since most other Soob's don't have one.
A better choice is to get the ring and pinion out of the new diff, and match it with the LSD carrier from the SVX diff. I think SVXfiles has the how-to in a link in his signature.
With this conversion, then yea, you'll be able to use your stock SVX axles.
Other than that, you'll also use the stock driveshaft, wiring harness and TCU.
Old 06-25-2007, 06:57 PM
Manarius's Avatar
Manarius Manarius is offline
Could always grab a 4.44 LSD from an Outback or a 4.11 LSD from a 2.5 RS...
Rare though.
-Jason
-Obi Wan Kenobi
Old 06-25-2007, 08:31 PM
Sconnie
so would any tranny at all other than one out of an SVX be a direct fit without messing with the rear diff?
