Old 01-08-2007, 10:50 AM
min's Avatar
min min is offline
95 SVX L - New owner
Send a message via AIM to min
steering/alternator
had this car since july. at first, the steering was very very difficult. then the belt started whining. took it in, tightened belt. all was good. started again. took it in, replaced belt. (oh, battery died between visits, and was told the alternator was bad). after belt was replaced, it was fine again. then it got cold, and it started whining (on exceleration and steering) took it back. he tightend the new belt and it was fine for a long time. now it's whining again, on steering and exceleration). any ideas of what i should say when i take it in again? could it be the atlernator making the steering tight and whiny?
Old 01-08-2007, 10:57 AM
How's the power steering fluid level? If your pump is on the way out that might explain things (heavy steering, whining..)
The alternator is just along for the ride and doesn't have much effect on the belt itself. If the alt. bearings are shot it should be making a rather unpleasant grinding noise.
Old 01-08-2007, 11:05 AM
dcarrb dcarrb is offline
It's probably not the belt whining; it would screech if the pump or a pulley were binding. An unhappy pump will groan and whine under load.
If it's not just low, try changing the power steering fluid and maybe top it off with a slug of Lucas power steering additive.
dcb
Old 01-09-2007, 12:33 PM
min's Avatar
min min is offline
his dad finally took the car out. said a couple of the bearings would stop and then start again. how expensive??
Old 01-11-2007, 01:27 PM
min's Avatar
min min is offline
now my son can barely steer the car. anyone want to buy a 95 svx? other than the steering, it's quite good. solid, tight. and he keeps it SO clean. (his job is detailing cars - so his car gets great treatments)
Old 01-12-2007, 01:18 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Sounds like a slipping crankshaft dampener to me.
