Old 01-02-2007, 06:14 PM
noitseuq noitseuq is offline
Tranny gear ratio Questions, please help im new to the svx world
Hey guys i just recently bought a laguna blue 1994 svx FWD immaculate condition and 75k miles.
My plans with the car is to convert it to a AWD 5 speed manual
What i have bought for the swap already is and COMPLETE drivetrain from driveshaft to hub / and sub frames off of an AWD 1994 SVX.
The tanny i think im going to go with is the 02-05 wrx tranny.
now the only thing im stummped on is that if i use the o2-05 wrx tranny it says i can leave the rear end stock?! the reason why im stummped is because isny the final rear of the svx like 3.45 or close to that? and isnt the wrx 4.xx?
someone please clear up my ignorance on this car and refering to what i have car and parts combined, what tranny do i need?
thanks much
Old 01-02-2007, 06:16 PM
2nd question
will the stock front axels pop right in an 02-05 wrx tranny ?
Old 01-02-2007, 07:52 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Young Tom (aka TOMSSVX) is your man for 5 or 6 spd mods (tipping my hat to Huck as I type this ). He's working out of his own garage space in Philly, so it shouldn't be much of a drive for you. Old Tom (SVXFiles), while the Father of the 4.44 AT mod, is also a possibility for you - he's west on 70 over in Cumberland (okay, Wiley Ford, WVa, to be exact )
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 01-03-2007, 06:09 AM
Yes they will. As always ensure you don't get the axles 180° out or you won't get the pin back in.
Old 01-03-2007, 08:57 AM
sperry's Avatar
sperry sperry is offline
$1 is just $1, but $2 = nachos
The '02-'05 WRX 5MT uses a 1.1:1 center diff. What that means is that it's got a 3.90 front diff and a 3.545 rear end, with an effective final ratio of 3.90.
Since the SVX's rear end is already a 3.545, the WRX 5MT is about as plug-n-play as a 5MT gets, you'll just need a 2" spacer on the drive-shaft IIRC.
3 turbos, 28 cylinders, 96 valves, 18 cams, 1400hp/1600ftlbs: '09 Outback XT / '06 Outback Sedan / '02 WRX / '94 SVX / '01 F-250 SuperDuty
