Old 04-15-2002, 08:33 PM
MoreIBNR MoreIBNR is offline
Original Owner 1992-2008
Send a message via AIM to MoreIBNR
OT - Audi 1.8T
Guy at work just bought a 1999 Audi A4 1.8T. Says the engine puts out 150 hp (I forget the torque figure) but with an aftermarket computer chip, the HP goes to 200 and the torque goes to 245 lb-ft. This sounds like an unbelievable increase just from a software upgrade and no hardware changes.
Does anyone out there have any idea how they accomplish this? Or is this a scam?
Old 04-15-2002, 09:47 PM
Shadow248 Shadow248 is offline
Rep from the outside world
Send a message via AIM to Shadow248
Umm...doubt it...the largest gain i ever heard of simply from a chip was 20hp. To get 50hp the factory would have had to detune the engine massively, and then it would get horrible gas mileage.
Old 04-15-2002, 10:17 PM
Red SVX 92 Red SVX 92 is offline
Hitchhikin'
That number is very real. I always thought the 1.8T's had 180 hp to start with, though. But yes, it does bump the hp number up to 200... not sure about torque. It wsa big news with the New Beetle owners, because the new beetle has the same engine as the 1.8T. After getting a chip, the turbo beetle gets the same power increase to 200.
Old 04-15-2002, 11:58 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Re: OT - Audi 1.8T
Check out www.audiworld.com
They will give you more than enough info on that audis.
Lwin
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 04-16-2002, 04:50 AM
wawazat??'s Avatar
Yeah, I'm still around
That number is real!
Early 1.8T's were 150hp in all applications (transverse (Golf, Beetle, Jetta, exc. TT) and longitudinal (A4, Passat)). They were later boosted to 170 and 180 hp (and 225hp in TT) depending upon vehicle. Chips from Neuspeed, APR, Autothority, Wetterauer, TAP, GIAC and others take the hp up to 200-210 and torque from 150-170 to 245 ft. lbs. This engine is massively detuned from the manufacturer.
My daily driver is a 2001.5 1.8T 5 speed VW Passat Variant (aka station wagon)
Down to none
Old 04-16-2002, 06:19 AM
Anybody have a clue as to how this actually works? I was under the impression that the chip (software) would deal with fuel mixture, ignition and trans shift points with an automatic. None of these sound (to my inexperienced ears) to be able to deliver that kind of boost without changing cams, etc.
Thanks.
Old 04-16-2002, 07:20 AM
Mr. Pockets's Avatar
Moderator
Thanks.
In a normally-aspirated engine, you're right - chips can't do too much because you need more air to produce more power.
But it's a little different on a turbo car because the machinery to get more air into the engine is there. The boost can be turned up, stuffing in more air and producing more power.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 04-16-2002, 11:48 AM
Is there a trade-off? Will the engine self-destruct sooner? Will the tranny (automatic) die early? Will the turbo melt down?
Old 04-16-2002, 11:58 AM
Moderator
I imagine you risk a lot of things, which is why the manufacturer had it turned down in the first place.
2005 Outback
END OF LINE
Old 04-16-2002, 12:55 PM
The more pressure you force into a turbo engine, the quicker things are going to go wrong. That's why i have always looked at turbos as a last resort way of adding HP.
Old 04-16-2002, 01:36 PM
Hitchhikin'
The more power you get out of the car, the less reliable it will be, in general. In particular, any modification that will substantially increase your power will also increase the load on those parts. It's why you have to upgrade other engine components along with it, in order to handle the load better.
Old 04-16-2002, 02:54 PM
EverclearAtMSU
Re: OT - Audi 1.8T
my friend has this exact car. He got the chip and it DID boost the car up that much. Only this was about a week after he had it installed, one of his turbos blew up. No joke. He's not sure if it was the result of the chip or if it was something wrong from the factory. He put his old chip back in and they replaced the turbo because it was under warantee. He's not sure if he wants to put the chip back in or not now...but everyone on the Audi forum that has this chip says they've had no problem w/ it. So, I guess it's up to you if you want to do it, but it does make that HP.
Old 04-16-2002, 02:59 PM
EverclearAtMSU
Re: Re: OT - Audi 1.8T
ok, he has the s4, 2.7t, sorry about that.
I'm talking to him now, he just got it back and the shop says there was a defect in his original turbo, so he's putting the chip back in
he got the chip from :
www.dynospotracing.com
and it's a giac chip
hope that helps you some
Old 04-16-2002, 04:05 PM
Green1995SVX
This is the case with the 1.8T. It is detuned so its not a direct competitor to the 2.8L V6. The 2.8 is detuned so that its not in direct competition with the 2.7T engine.
hope that helps.
-Mike
