Old 04-15-2002, 03:54 PM
BillInUrEye
Removing grille
I am trying to take off my grille, and feel really stupid cuz I can't figure out how to get it off. Can someone please tell me what I'm doin wrong?
Old 04-15-2002, 04:23 PM
Green1995SVX
Asuming you have a 92-96 SVX, there are 2 clips at the top. Simply pinch the clips and tilt the grill forward until the clips clear the housing. There are now 2 rubber nubs on the bottom of the grill holding it in place. Just lift straight up and out, and this will disengage the nubs.
If you have a 97, the process is the same, but you have 4 clips at the top.
-Mike
Old 04-15-2002, 05:37 PM
EverclearAtMSU
Re: Removing grille
I had the same problem. Dont worry about it. I found that rotating it towards you and up works pretty well. do the same thing to put it back in.
Old 04-15-2002, 06:59 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
This is one of the clips
Look at this pic.
http://stevebsy.crosswinds.net/removal/P0000957.JPG
I find a needle nose pliers works pretty well to squeeze them, then as squeezing, pull it forward slightly so it is no longer locked in. Then do the other side, pull forward a little and then up and out it comes.
Check these pics for the grill being removed further:
http://stevebsy.crosswinds.net/removal/P0000958.JPG
http://stevebsy.crosswinds.net/removal/P0000959.JPG
Good Luck
'20 Honda Ridgeline
http://www.x35design.com
Old 04-16-2002, 06:30 AM
BillInUrEye
Thanks Everyone
