Old 12-20-2006, 12:37 AM
Gravija Gravija is offline
Send a message via AIM to Gravija
whining sound when i press on gas
hey
my 93 SVX makes a weird whining noise when i press on the gas and it increases in volume/pitch as the RPMs do
what could this be?
it has done this before but only on occasion, now it is every time i drive the car and it is getting kind of annoying
anything i can do to fix it?
thanks
Old 12-20-2006, 02:02 AM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Sounds like an idler going bad or maybe power steering? Take a listen and see if you can find the general vicinity of where the noise is coming from.
Old 12-20-2006, 02:28 AM
dwd1985 dwd1985 is offline
Depending on what the "whining" actually sounds like, it could be an exhaust leak.
Old 12-20-2006, 11:47 AM
drivemusicnow's Avatar
Poor College Racer
Sounds like some alternator whine to me.
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 12-20-2006, 11:54 AM
SubaSteevo's Avatar
No longer blue member
Do you have a stereo amplifier installed?
-Steve
01' MSM Lexus IS300
Old 12-20-2006, 12:23 PM
i just replaced my power steering a couple months ago
i will check where the sound is coming from later, but i do not have an amplifier installed, everything is stock
what would it sound like if it were an exhaust leak?
Old 12-20-2006, 12:28 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Check all your vacuum hoses too.
Old 12-20-2006, 04:18 PM
I cant really describe the exact sound of an exhaust leak, but what you should try would be warm up your SVX, leave the door open, stay in park and hit the gas, and if the sound is coming from directly underneath you, it would probably be an exhaust leak.
Old 12-20-2006, 04:41 PM
Better still, block the tail pipe with a rag in order to produce back pressure.
Old 12-20-2006, 05:48 PM
It's Just Eric's Avatar
Missing in action
If you have a younger sister, you can have her take the bus to school. now you can accelerate as much as you want and not here whining.
(Sorry, couldnt help myself)
If it's an electrinic, "Your grandma's old tv withy the volume all the way down" kinda whine, its alternator whine. I have NO idea what causes this, but Im sure Trevor does. If its more of a mechanical thing, I'd suspect first a bad bearing on the power steering pump, ac condensor, or alternator.
R.I.P Cool Signature.
Old 12-20-2006, 06:22 PM
How the hell would I know, who where or what nasty thing is objecting. If alternator, you are right to first suspect bearings, but is it the alternator or a girl friend,
Old 12-20-2006, 06:57 PM
Karl Karl is offline
hmmmm yes...sounds like you need to replace your muffler bearing:
Old 12-20-2006, 07:09 PM
Edit ---- With a muffled muffler bearing!
Old 12-21-2006, 04:06 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Could be your tires...Mine make a higher vibration whine...I think a belt shifted inside the tire tread...I rotated the tires and the sound minimized from the front where it was originally coming from.
1995 Subaru Svx L / AWD
Old 12-21-2006, 12:51 PM
could it be from a tape ipod adapter?
after i took it out i didn't hear the sound but i only took it once around the block and back, so i don't know if its really gone...will update later
thanks
