Old 12-16-2006, 11:54 AM
danyvaly danyvaly is offline
transmission questions
I have a 1994 2wd tranny. it has 130 k.
The mechanic says it needs two quarts of oil. he checked the oil and said oil is fine and is not smelling burn.
I run the tranny for 1500 miles like this. Did the tranny suffer? The tranny runs smooth it has never been rebuild.
another question:
when is going to shift to second it does it at at 3000 rpm instead of of 2000 rpm. can this be fixxed without a rebuild?
q3
what oil do you recommend? also the mechanic told me to use an additive is this wise?
thank you
Old 12-16-2006, 03:07 PM
another question:
q3
thank you
As long as it did not slip too much, before the oil was toped up. The shift into 2nd may be helped by adjusting the brake band.
