Old 12-03-2006, 01:37 PM
shotgunslade's Avatar
Atco Dragstrip
MikeCG, TomsSVX and I were at Atco this morning for a Test and Tune, my very first drag strip drive. We were joined by Mike621 and Its Just Eric, there to spectate
Will let Tom and Mike tell you about their drives. Tom had a bit of misfortune. My first two slips (I'm car 111):
Then, I asked Tom to drive my car to show me how it should be done.
He said he wouldn't try to get everything out of it, that he would baby the clutch a little bit at the start.
But, he still managed to best my time by 0.3 sec. He said he thought there were still a few more tenths to be taken out of the time with a more aggressive rev's and clutch drop at the start.Results were 0.3 better than my best. When you want it done right, go to an expert.
Old 12-03-2006, 02:43 PM
thanks for the compliments Dan, I don't really have much to say about today but... **** happens. It was good to see everyone today and have a good time back at the track... It has been close to a year since I last went. I will be back again sometime but it doesn't look like anytime soon. I am going to follow my modo and with every repair make it a modification... Built EG33 comming this year
Old 12-03-2006, 02:48 PM
n00b on demand's Avatar
so what did you break now tom?
Old 12-03-2006, 03:49 PM
piston rings or there is just a nice big hole in one of them
Old 12-03-2006, 04:06 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Nice pics! Great times Dan (and Tom driving your car).
Sorry to hear about your engine Tom. Good luck rebuilding her stringer and better!
-Chike
2006 Steel Gray WRX TR (sold)
Old 12-03-2006, 06:24 PM
SomethingElse's Avatar
word words wording
Tom ive got a couple engines in the garage with just over 100k. Let me know if you need anything.
Eric
Old 12-03-2006, 06:45 PM
jsvxstyle jsvxstyle is offline
MINEZ BETTER
tom this is jsvxstyle, also with the blower, what was your exhaust temp, when your motor melted, do you want want fries with that, give me a call for our issues, 925-584-5737 call me @ any time,
white leathers, h.i.d, ecutune S/C stage 4, 14 inch 2piece rotors big brake kit., , msd ignition, c/f dash kit, front spoiler,carbon fiber jdm rearc wing,19 inch rims, nos, , aem fuel regulater, koni-gc package, ported cylinder heads, supercharger cams,solid buck and shims,wrx sti intake valve and exhaust valves,& valve springs, gas analizer,water injection, exhaust temp gauge, idiglo gauges, shift kit, , remote start, all automatic windows,2.5 inch true dual exhaust system with crossover, and 2 borla stainless steal muffler,air filter velocity air stack 3inch to 6 for air filtre, group n mounts, momo steering wheel, dyno will happan soon
Old 12-03-2006, 06:50 PM
MINEZ BETTER
i need one how much, thank, i got french fries with mine
Old 12-03-2006, 11:44 PM
are you saying that you popped your motor too?? I do not have an EGT gauge nor a wideband... I was monitoring the knock sensors which did nothing for me just after I cleared the ECU... Anyway... I may be in for a motor from you... know what you want for the lower mileage one?? I have my eye of a 52k engine but the seller may not want to part with it... So let me know what u r thinking
Old 12-04-2006, 01:05 AM
NeedForSpeed NeedForSpeed is offline
Double motor melt with fries, not good.
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 12-04-2006, 01:09 AM
Mike, what about Mike?
Old 12-04-2006, 05:08 AM
mikecg's Avatar
mikecg mikecg is offline
I made out fine. I didnt set any new records. Here's the stats off my best run:
R/T: .669
60': 1.884
330': 5.744
1/8: 8.987
MPH: 74.62
1000: 11.761
1/4: 14.142
MPH: 95.70
That was my fastest for the day. Strangely it felt like my slowest. But that could be because I was lined up beside a 10 Second car.......
I was faster than both Tom and my fathers Trailblazer SS. But considering Tom was having problems and nuked his motor, I wont consider it a win. Had a pretty good time all in all. Now I need to figure out how to test the software Tom didnt get a chance to run.
Old 12-04-2006, 09:14 AM
Nice run Mike. Nine psi?
R/T: .669
60': 1.884
330': 5.744
1/8: 8.987
MPH: 74.62
1000: 11.761
1/4: 14.142
MPH: 95.70
Old 12-04-2006, 06:00 PM
Chiketkd's Avatar
Thumbs up
Nice time and amazing 60ft Mike!
Old 12-04-2006, 08:27 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
So, are we coming to the conclusion that the stock engine doesn't like 12psi of boost
Mike - any traction issues on your 14.1 run? What rpm did you drop the clutch at?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
