Old 11-29-2006, 09:57 PM
hexadec0079's Avatar
hexadec0079 hexadec0079 is offline
Parts Breaker, Tire Waster
Send a message via AIM to hexadec0079
4.44 is a GO!!!
Finally, picked up the car today.
After much haggling and minor fixes and stuff, it is mine again.
4.44's feel much better and positive. Car is much faster. I can feel the front tires scramble for grip and spin a hair when I take off hard. Power mode is AWESOME. Very satisfied overall with performance.
A couple questions-
I got home after leaving the shop and stopped at my friends for 30 min. and left and looked for leaks... nothing. Drove around for an hour. Got home and moved car after a couple hours, about a cup of ATF leaked, F$%#... But now its not leaking any and the fluid is still full and BRIGHT pink. What gives, I think they overfilled it and it pushed out the dipstick.
#2-
I have a slight hesitation at 1500-1800 rpm. Seems like it bogs a bit. Goes to 1500 slows revs and acceleration by half til 1800 and then it is fine, IDK...
Doesn't happen in Netural. Tried Manual 2nd gear, still happens. Any thoughts?
#3-
16 Blinky lights at startup, intermittent. No problems I have experienced, any thoughts. Will perform tests tomorrow
1992 SVX- -Drivetrain by BUDFREAK-
Green, LS with spoiler, 157,000, ES Swaybar bushings, 9005/6 mod, 2.25' Dual Exhaust, Custom Grounding, Hyperwhite fogs, LED tails, 4.44s, custom Blitz intake, tranny cooler, thats about it, for now...
1997 Chevy 1500 -FOR SALE-
5.7 liter, Z71, 300hp+, still almost 20mpg
1986 Merkur XR4Ti -SOLD-
SVO Engine, T3 hybrid turbo, K&N, custom ducting, Initial D painted, 18psi, fastest car for under $1000, ever.
Old 11-29-2006, 10:23 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
A couple questions-
#2-
Make sure you sign up on the 4.44 sign up thread. Congrats my man and I hope all works out well in the future. I gotta run but I'm sure somebody will be along soon to help with the questions.
Old 11-29-2006, 10:34 PM
TCU test reports Solenoid A malfunction. What is with the Sol. Part in near the battery that I've heard of. Internet won't let me search "Solenoid A" b/c A is too short, whatever.
It still all good though.
I don't think its Trans. related as it happened with the old trans. please help, thanks
Old 11-29-2006, 10:55 PM
Budfreak's Avatar
Banned
I sent you a PM. We can fix this easily.
Old 11-29-2006, 11:26 PM
might seafoam engine then Xylene to help with hesitation. thanks to Budfreak for all his help.
Old 11-30-2006, 12:24 AM
Budfreak's Avatar
Banned
Xylene won't be necessary. Just use 10 Ozs. of sea foam in the oil, Use it per the directions in the gas, and then suck some through a vacuum line to clean the valves and intake and so on.
Get some STP throttle body cleaner too and do your throttle bodies.
Old 11-30-2006, 01:14 AM
well the xylene wasn't for hesitation, more for overall performance. But thanks for the input
Old 11-30-2006, 10:41 AM
A couple questions-
--- gotta check and see where it is comming from... Oil doesn't just find a way out, there has to be a leak. check the connections of the cooler lines and make sure one doesn't just need to be tightened
#2-
--- Sounds like you have not done the ECU bead crush... also check that your TPS is working properly
#3-
--- I see it is a solenoid A. this is "usually" the trans resistor behind the battery. check to see if it is connected and then check it's resistance
I posted in the quote... Glad to hear all is working well otherwise
Old 11-30-2006, 10:47 AM
GOT2HAVESVX's Avatar
GOT2HAVESVX GOT2HAVESVX is offline
What blue lights?
Send a message via AIM to GOT2HAVESVX
I gotta ask.....what does the xylene do? I just ordered 110 gallons of the stuff for work and never heard of it now I see it posted in here as some kind of fix!
Life begins around 70 MPH and stops when you dont see the flashing blue lights anymore!
Scott & Audrey's Subaru SVX's
1995 Green
1992 Black
Old 11-30-2006, 12:52 PM
Budfreak's Avatar
Banned
Octane booster more or less. I prefer to buy the NOS race formula booster. Safer and gives me 6 full octane numbers.(100 octane on Sunoco 94)
Old 11-30-2006, 01:19 PM
yeah, the next time I see an octane boosted pick up 6 points in the real world I will start buying it... but until then...
No offense to you but having experience with that stuff you will be lucky to see 2 points of 94
Old 11-30-2006, 01:24 PM
Budfreak's Avatar
Banned
All I know is I hit the 14's with it and the label clearly said 60 points or 6 octane numbers. I get my stuff from 2 miles away at a little place called Summit Racing and I'm sure they have a little better stuff than autozone or advance sells or whatever most of you are use to.
Old 12-01-2006, 12:47 AM
OK, so after thunking to school without any sway bar bushing. I got home, and JUST finished up the install.
Note- the correct sized bushing helps, I bought ones that are 1mm smaller bore and bigger in all other aspects. Worked pretty well, squeezed 'em on. No play now!!!
Yeah I was thinking about the ECU crush mod as it happens in all gears, but not in neutral. So I don't think its the TPS, but I'll check. I'll do the crush mod tomorrow.
ATF fluid appears to be drips from PS system. Different shades (new tranny, old in the PS resevoir)
Budfreak is helping w/ Sol. A ***THANKS AGAIN***
Waiting for tomorrow night to do Seafoam and change. I am kinda worried about hydrolock, how hazardous is it really?
Old 12-01-2006, 10:37 AM
sicksubie's Avatar
what are the mpg ratings that you can expect if you do the 4.44 swap?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 12-01-2006, 12:29 PM
Budfreak's Avatar
Banned
I get about 19-21 MPG average. I'm not the slowest driver around either.
