Old 11-07-2006, 10:18 PM
SubaRyu's Avatar
SubaRyu SubaRyu is offline
Domo Arigato
Head light level Adjustment?
Seems like my lo-beams are aiming bit lower and I've tried to adjust with those screws right next to the lo-beam housing, but didn't change.... Am I supposed to turn way more?? Or was I turning wrong screws?? I thought those were the level adjustments. If anyone could explain how to adjust the level, that'd be great!
Thanks.
-Ryu
Links:
2004 Honda S2000 (2008~)
1992 Subaru SVX LSL Liquid Silver (2007~2008)
1996 SVX LSi Bordeaux Pearl (2006~)
2002 Lexus IS300 Sportcross (2005~)
1992 Subaru SVX LSL Pearl White (2001~2005)
1994 Mercury Sable GS (1999~2001)
1/43 Scale SVX Models
[SIGPIC][/SIGPIC]
Old 11-07-2006, 10:49 PM
Sr240sx's Avatar
Sr240sx Sr240sx is offline
The little levels on my headlights are broken so I just do it by the "drive the car up against a garage and use the door to adjust them"
My '95 SR20DET powered 240sx track car.
http://www.cardomain.com/ride/2161953
Old 11-08-2006, 04:53 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
it only works if your driveway is flat...mine driveway is crooked....but I think my car sits crooked anyways too
1995 Subaru Svx L / AWD
Old 11-08-2006, 04:55 AM
Sr240sx's Avatar
Driveway isn't flat, but you can stand in front of the car and see how high up your legs the light shines
And then level them against the garage door.
Old 11-08-2006, 10:18 AM
PDSides PDSides is offline
Old Guy
You guys are way too scientific about this. Just make sure it is dark, then put on your favorite baseball cap (or fishing cap if you live in the South). Turn on your car's bright lights and walk fifteen long paces directly in front of the car (it is important that the engine isn't running). Turn and face the car covering your eyes with your forearm. Squat. Tip your cap's brim forward (put it on right, not backward, idiot) until the light doesn't make you squint. If you can still see part of the car your lights are OK. If all you can see is the ground you need to raise them a bit. Give it a try.
Preston
Old 11-08-2006, 10:37 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Make sure your car is level, use a level on the door sill. Check that the bubble on the settings of your head lights correspond with the level on the sill. If you want higher beams (bubble should be more towards the front of the car), If you want lower beams (bubble should be more towards the back of the car). Try all the screws one at a time to see if it affects the bubble. Then set as desired.
Old 11-08-2006, 10:40 AM
msvx95's Avatar
It's just a phase
how do you see the light if your forearm is covering your eyes...then tipping the cap lower wouldn't mean anything....hmmm I guess I should try it....
Um..why turn the engine off?....
Old 11-08-2006, 05:36 PM
SubaRyu's Avatar
Domo Arigato
Yeah I tried screws that looks like holding the lo-beam, but it didn't do anything...at least it didn't look like it did anything. So wondering. Maybe try more again??
-Ryu
Links:
[SIGPIC][/SIGPIC]
Old 11-10-2006, 04:42 PM
SubaRyu's Avatar
Domo Arigato
Sorry I was able to adjust the lo-beam angle by those screws... I just used power screw driver this time. If you use it, it's so easy to adjust. Now my hi-beam and fog lights are aiming too high... Hope there are separate adjustments?
-Ryu
Links:
[SIGPIC][/SIGPIC]
Old 11-13-2006, 07:13 AM
The fog lights can be adjusted but you must open up the headlight assembly to do so
Old 11-13-2006, 12:27 PM
SVX_MY_BABY's Avatar
Here's what Subaru and Chilton say.
1. Park vehicle on level ground about 25 ft. from a flat wall and remove any heavy objects from the cargo area.
2. Check tire pressure is correct.
3. Make certain that the vehicle's gas tank is full and that someone is seated in the driver's seat.
4. Bounce the vehicle several times to normalize the suspension.
5. If not using the gauges switch on low beams. The vertical height of the light beams above the ground should be 4 in. less than the distance between the ground and the centre of the lamp lenses for the lights.
6. Use a suitable wrench or socket to adjust the level indicator nut at the end of the level.
7. If using the level the bubble should not deviate from centre of the sight glass more than 2 marks vertically and one mark horizontally.
Old 11-13-2006, 04:36 PM
Old Guy
3. Make certain that the vehicles gas tank is full and that someone is seat in the driver's seat.
FOUL! (Or is it FOWL?) No fair, you actually looked up the answer. I was enjoying the more innovative methodologies. Somebody should write a book.
Preston
Old 11-13-2006, 07:38 PM
Preston
Err, ahh, oops
Old 11-13-2006, 08:02 PM
SubaRyu's Avatar
Domo Arigato
Hey thanks for the instruction in detail! I just aimed/adjusted till I feel comfortable driving at night. Not perfect and correct way to do it though.
-Ryu
Links:
[SIGPIC][/SIGPIC]
Old 11-13-2006, 08:07 PM
SubaRyu's Avatar
Domo Arigato
Really? that must be really hard to adjust! I thought there was another screws to adjust. Ever since I installed HID, I hardly use the fog lights. And after I put the clear lens, fogs don't focus well, that's trade off of having clear lens.
I just drove back from work, I just wanna say I really love how HID work.. I can see way better than I thought. This is way better than I had expected.
-Ryu
Links:
[SIGPIC][/SIGPIC]
