Old 04-14-2002, 10:38 PM
MoreIBNR MoreIBNR is offline
Original Owner 1992-2008
Send a message via AIM to MoreIBNR
Originally posted by gcookaustin
Oh. Well, I saw two at the front which are hidden when you close the door, one inside the "pocket" area that was more difficult to get at (or even see), and one screw around the corner which is also not visible when the door is closed. I'll do a search for removing the door. I just feel like I'm about to break something I can't afford when I pull on the door panel...
There are 3 screws in the arm rest under the felt. There is 1 screw behind a plastic piece which snaps out behind the door handle. Those plus the ones at the front that are hidden when the door is closed are all there are. The door panel is held on by clips down the sides and across the bottom. Pry them out carefully. Lifting the panel off the top is easier if you have the window down.
Old 04-14-2002, 11:14 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
The driver's side switch cluster is part #1 in this diagram.
http://www.subaruparts.com/diag/?mod...category=816-A
For the 92, you get auto up/down. If you want to spend a little less money, you can order the part number for the 94 and later models that only has auto down.
Randy Johnson
Mike Davis -- at Reading VI
Old 04-14-2002, 11:20 PM
gcookaustin
Ah, I see; I didn't see the 1 just the A. Yeah, I think I might just wait until it doesn't work anymore and then order the new part, since my passenger side switch is missing anyway (so there are a total of THREE things wrong with my window switch cluster, that's grounds for a new replacement!) Also I would like to get the button to open the center console but I'm not sure how to change it out? The part just broke today when closing it. I guess I could just glue that back together with some superglue or something? I didn't see anything come loose except the button.
Old 04-14-2002, 11:23 PM
Aredubjay's Avatar
I'll have to give a look-see on my car to be able to advise you further on the button. I'll take a look tomorrow and post, unless someone else has an answer.
Randy Johnson
Old 04-15-2002, 01:04 AM
gcookaustin
I walked a couple of blocks down to my car at 2:00 AM to check myself (I make all kinds of excuses to see my new car ) and there doesn't appear to be any way to install a new button without taking the whole center section out. Fortunately though the button looks like you can just glue it back on and it will be okay.
