Old 10-11-2006, 06:40 PM
Pure_Insanity8's Avatar
Pure_Insanity8 Pure_Insanity8 is offline
Send a message via ICQ to Pure_Insanity8 Send a message via AIM to Pure_Insanity8
You should probably check your speedometer accuracy, then... or check to see if you have the elusive JDM turbo version.
-Aaron
SVX: '92 Dark Teal 101k
'97 Legacy GT Wagon: dead
'99 Civic Si: daily driver... stolen and stripped with all my tools!
'92 Yamaha FZR 600: garage
2011 Jetta: Daily disappointment
Old 10-11-2006, 07:00 PM
curly2k3's Avatar
curly2k3 curly2k3 is offline
Own'eded
Send a message via AIM to curly2k3 Send a message via MSN to curly2k3
nah, its the JDM Police Intercepter Turbo!
98 Impreza Wago-O-Doom & Datsun Roadsters
Old 10-11-2006, 08:26 PM
Archer999's Avatar
Archer999 Archer999 is offline
Arrow Turbo
I havent seen a turbo under my hood. How would you check for JDM.
All these people knocking the speedometer. How inaccurate do you think these gauges are. Do you think that the gauge is 10-15 mph off???? or more???
I have been driving a looong time. The gauges are fairly accurate and, like I said the car was beggin for more. Could have gone faster
I have never heard of this elusive turbo model. I thought the touring package was the top o' the line for factory output. I am interested in this turb. Do you have any pics or links plz
Old 10-11-2006, 08:45 PM
curly2k3's Avatar
Own'eded
lol, site joke...you will learn younge grass hopper
only i have it anyways...i hord the pics for myself
Old 10-11-2006, 09:29 PM
Archer999's Avatar
Arrow Alcyone
So, did they manufacture a line of just Alcyone. With the tail light and emblem or is that just all aftermarket stuff?
Old 10-11-2006, 09:38 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Originally Posted by mikecg
I'm making far more then 135HP at the wheels. The gear ratio is what is restricting my speed.
Do you have the breakdown ratios for all 6 gears? What is your final drive ratio? It seems pretty low.
So Tom who did your swap have the same ratio tranny as you now?
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 10-11-2006, 10:43 PM
Yes, the speedometer can easily be off by that much. Over 100 mph as they come from the factory, they are usually off by close to that much. Lighter cars with less drivetrain loss, 100+ more ponies, and similar coefficients of drag, still don't accelerate very fast after 100 mph. Look at LS1 cars, they can get up to 150 without much trouble, but after 130 or 140, they need plenty of time and room to keep going faster.
-Aaron
Old 10-12-2006, 01:21 AM
92svx95 92svx95 is offline
heheh with lans stage1 chip, dayles stage2 intake and 4.44 gearing i've reached 150 no problem. had plenty of space and rpm left and it kept pulling. but i feared for my tires. 2 weeks later i had to replace em=] when she was stock i reached 140 and she was still pulling. but not as hard as the 4.44 1 more week tell i get stebro cat back exhaust =]
did i mention both runs where tacked by gps =]
Old 10-12-2006, 02:04 AM
ItsPeteReally ItsPeteReally is offline
150mph, 4.44 gears, and plenty of rpm left?
When I try and work that out, I get around 6,400 rpm.
I often say that when you can measure what you are speaking about, and express it in numbers, you know something about it; but when you cannot measure it, when you cannot express it in numbers, your knowledge is of a meagre and unsatisfactory kind; it may be the beginning of knowledge, but you have scarcely in your thoughts advanced to the state of Science, whatever the matter may be.
Sir William Thomson
Old 10-12-2006, 04:55 AM
mikecg's Avatar
mikecg mikecg is offline
Originally Posted by Pure_Insanity8
Ordinarily a car's speedometer is a few mph off by even 45. Manufacturers gear the speedometers to read over your actual speed with the given gear ratios and tire sizes.
Putting the car on a chasis dyno to check speedometer accuracy works very well. I have seen dozens of cars go through this procedure and almost all are 10% off by 45-50 mph. My Civic was actually the closest to accurate I have seen (only 3 mph low at 110 mph indicated). However, when I changed my tires and ran it again, I was close to 5 mph under indicated by 75. Both sets of tires were stock sized as well.
That equation for power required to overcome wind resistance is also quite accurate. With a stock 4EAT, EG33, and the 3.54 final drive, actually hitting 150 mph should be nearly impossible. Sonar's speed seems to be tough to hit but within the realm of possibilty with a 3.70 final drive... and I thought he was drafting when he got there.
Mike, you were really at 7300 rpm at 135 mph? I thought the 6 speed had the same 6th gear ratio as the 5 speed's 5th, and with the 4.11's and at 7k... it would be hitting around the 155 mph mark.
I havent accually been over 120. But at 120 I didnt have much left. The JDM 6-speed has a different 5th and 6th. Cruising at 75MPH I turn 3500RPM in 6th. I also have aftermarket wheels and tires, which means my speedo is off. I just dont know how much or which way.
Old 10-12-2006, 05:00 AM
mikecg's Avatar
No I dont have the gear break down. Although I would like to find it, and yes Tom has the same tranny.
Old 10-12-2006, 05:02 AM
mikecg's Avatar
I believe all of LANs chips raise the Redline fuel cut out to 7300rpm. Ok Ithink I'm caught up with this thread now. Time to move n to the next.
Old 10-12-2006, 10:27 AM
That means at 7300rpm you would be going about 156mph.
Old 06-20-2007, 10:27 PM
svxman07's Avatar
svxman07 svxman07 is offline
Send a message via AIM to svxman07
top speed
i hit 145mph in my 94 ls with a freshly rebuilt auto tranny and still had atleast another 15 mph to go when i got my friends dad who is a cop to clock how fast it would do, had to start slowing down or i would have topped it out
