Old 08-28-2006, 06:27 AM
seion seion is offline
Subaru Engineer Wanabe
How many circular clips for differential?
Putting my rear diff back on and wanted to ask you guys how many circular clips (CIRCLIPS) are on the axle rods that connect to the differential. It is #14 on the diagram. I thought I only needed one on the driver side (left) but I need to double check w/ you to see if I need one on both of the axle rods that connect to the rear diff.
Cars I've worked on:
'05 Subaru Impreza STi, '02 Subaru Impreza WRX Wagon, '01 Toyota Celica GT, '98 Subaru Legacy GT 2.5 Sedan, '96 Isuzu Rodeo, '95 Jeep Cherokee 2WD, '94 Plymouth Sundance, '94 Subaru SVX LSi, '93 Subaru Impreza, '92 Subaru SVX LS-L, 2003 Subaru Baja.
Old 08-28-2006, 07:00 AM
Speedklix's Avatar
Locker Link Solution
1 on each...
Sometimes 1 will get stuck inside, I just center it so that I can fit the end of the axle stub in and just ram it in. Much easier than trying to fish it out. If both are out, you are all set. Pop em on and slide em in!
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 08-28-2006, 11:04 AM
Originally Posted by Speedklix
1 on each...
Then I think the rear-right one got stuck inside the diff. I'll take a look today (and get gear oil all over) and see if it's there. Probably will order new ones anyway.
