Old 08-21-2006, 10:03 PM
wannarace928's Avatar
wannarace928 wannarace928 is offline
Send a message via AIM to wannarace928 Send a message via Yahoo to wannarace928
Classic SVX
Catalytic Converters
I recently bought a 1992 SVX, and had to jack up the rear end because it has been making a noise while accelerating and found the problem to be one of the catalytic converters has been dented in. Anyways, while it has been up in the air, I noticed it has 4 catalytic converters on it, why is there so many? Does it really need that many? Wouldnt it decrease performance to have so many? Can any be removed and put straight pipes in? Like the dented one? Thanks
Old 08-22-2006, 01:56 AM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
There are only 3 cats. The first 2 are pre cats, the 2-1 is the main cat, And the last one you see is just a resonator. I had custom pipes made to replace the front 2 cats and put on a magnaflow 2-1 cat in place of the stock unit. You actually lose performance from taking off all the cats due to the fact our engines seem to like having a little backpressure. Where are you in Ohio?
Old 08-22-2006, 10:00 AM
Here is the exhaust system diagram. Which one and just how dented is your converter? Are you sure it is the converter that is dented and not the heat shields that surround them?
Old 08-23-2006, 04:28 PM
Classic SVX
It is actually the resonator that is making the noise then. It is no longer dented but still making the noise. Does this just need to be replaced?
I'm from Columbus.
Old 08-23-2006, 04:29 PM
Classic SVX
Thanks so much for the photo! it really helped.
Old 08-23-2006, 04:41 PM
Mr. Pockets's Avatar
Moderator
I recently replaced my resonator with a straight pipe. The buzzing mine made is gone, but the car is definitely louder. I'd call it 'flatulent.' I've even heard it make a few muffled pops if I rev it.
I'd rather the car was dead quiet, but it's better than the buzzing.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 08-23-2006, 06:54 PM
immortal_suby's Avatar
Thread Killah
if you just want a cheap fix go with a straight pipe. If you want it to still be quiet have them put a glasspack in there.
Locker Link
2015 BRZ Limited 6MT
Old 08-23-2006, 07:49 PM
Classic SVX
What is a glasspack and where can you find one?
Old 08-23-2006, 08:10 PM
92SVXLS-LDC's Avatar
92SVXLS-LDC 92SVXLS-LDC is offline
i straight-piped my resonator, wasnt too loud at all... my buzzing went away, then came back!!! like a week later!!! its not AS loud, but more annoying than ever, anybody explain that?
'96 Saab 900 turbo
'95 Passat (drove the wheels off)
'92 SVX Ls-L (smashed/sold)
'88 Acura Legend (wheel fell off)
'90 Audi 80 quattro (50mph into side of truck)
'95 Saab 9000cse turbo (sold)
Old 08-23-2006, 11:30 PM
Gloomy's Avatar
Gloomy Gloomy is offline
Did you see any performance loss/gain after removing the resonator?
Old 08-24-2006, 03:39 AM
no, not at all... i also took care of a major exhaust leak at the same time, if that counts for anything...
'96 Saab 900 turbo
Old 08-24-2006, 09:36 AM
svxcuseme's Avatar
svxcuseme svxcuseme is offline
5 speed 4 sure
Yes, removing the pre cats will give you buzzing, resonation. I have straight pipes welded in. I get it around 3k rpm. Hindsight! Very annoying.
Anybody had any success using aftermarket pre-cats ? Which model?
Old 08-24-2006, 06:38 PM
Thread Killah
a glasspack is just a straight thru tube type resonator. Usually only abour 4" diameter and packed with fiberglass around the edges. Most auto parts stores will sell them right over the counter. Any good muffler shop will have them in stock. Summit racing or Jegs sells them cheap also.
Locker Link
Old 08-24-2006, 10:14 PM
Gloomy's Avatar
Thankyou
Old 08-25-2006, 06:01 AM
svxcuseme's Avatar
5 speed 4 sure
Any thought on ....
