rear tail lights; tiny issue
I've just replace the water pump, timing belt and all that goes with it, so this question is so very small. The back tail lights seem to hold moisture in them. They look foggy. Is there a fix to this, or is it just insignificant? (let's hope this is all I face for awhile).
Failure of the lens seal to the body of the light is one possibilty. Could dry out the interior and apply a thin bead of silicone.
Gene
Gene and Ben 1992 SVX LS AWD 110K - Liquid Silver 1994 SVX LSi AWD 128K - White Pearl (daily driver) 1994 SVX LSi AWD 95K - Emerald Pearl (sold) 1992 SVX LS-L AWD 115K - Dark Teal 4.44 swap (sold) |
Take the lenses off and put a hair dryer to the bulb holes to dry it out until you are sure they're dry. Then reinstall and swap the gaskets so they are on opposite sides (or install new gaskets).
You can also drill a very tiny hole at the bottom of the lens.
-Steve Member #895(the member formerly known as BurgundyBeast) 01' MSM Lexus IS300 |
Try the "search" function....
This topic has been covered several times, with multiple suggestions for getting the moisture out and keeping it out.
Try searching "tail lights condensation fix" or the like.
Diana 1992 Liquid Silver LSL, >230K -- "Silver Bullet" // dimpled/slotted rotors, SS brakes lines, 5000K HID headlights // TRI-TONE paint |
My fix:
- dry them off - put silicone on the gasket where it contacts the taillight - put grease on the gasket where it contacts the body - reinstall
getting the lenses off
the lenses are impossible to get off without snapping them. any suggestions?
Don't have to remove the lenses, just the entire assembly.
Tail light condensation.
Subaru ECU and TCU Website 1992 Alcyone SVX Version L 1992 Alcyone SVX Version L 1994 Alcyone SVX S40-II 2004 Subaru Legacy 2.5 SE Sports Tourer 1996 Subaru Legacy 2.2 GX Wagon 1988 Subaru Justy J12 SL-II |
Thread Tools | |
Display Modes | |
