Old 08-10-2006, 04:43 PM
SVXgarcia SVXgarcia is offline
Send a message via AIM to SVXgarcia
Oil leak
where do oil leaks most commonly come from? I have a leak that seams to be coming from both left & right side of the engines. Its not a leak that leaves a puddle(not yet). The oil slowly moves to the bottom of the engine and forms a drip around the oil tank. Its not the oil tank leaking because there's oil all over the engine. Any suggestions?
Old 08-10-2006, 04:51 PM
depends how far forward you see the oil. Usually it's the cam seals or the valve cover gaskets.
Old 08-10-2006, 05:11 PM
sorry for the question but where is the Valve cover or cam seal? Is this something that I can get replacement seals or gaskets for?
Old 08-10-2006, 05:18 PM
immortal_suby's Avatar
Thread Killah
the valve cover seal is inside the valve covers on each side of the engine. you can buy and replace them. the drivers side is a pain and the passenger side is pretty easy to do. this thread should help you out
http://www.subaru-svx.net/forum/show...e+cover+gasket
Locker Link
2015 BRZ Limited 6MT
Old 08-10-2006, 05:28 PM
The cam seals are behind the timing belt cover. Those are best changed when the timing belt is changed. If they are leaking then save up and change a bunch of stuff while you're in there.
Old 08-11-2006, 05:24 PM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
While changing the cam seals what else should be changed? I guess I should start saving up.
dustin
-Dustin
Old 08-11-2006, 05:30 PM
Thread Killah
dustin
bare minimum - front main seal, cam seals, timing belt
medium - timing belt idler pulleys, timing belt tensioner
hardcore svx hypochondriac- all above + water pump & oil pump
Locker Link
