Old 08-04-2006, 10:34 AM
DarknessofDeath's Avatar
Inhabitant of Darkness
magnaflow cat install
has anyone installed a magnaflow 2-1 cat in their car?
was it welded into place or did you have it done with custom piping?
thanks.
i was hoping that it would have been just a direct swap but it's not the case.
Old 08-04-2006, 10:43 AM
Mine is a cat back system and there was some custom welding done. Good luck.
Old 08-04-2006, 01:01 PM
I had 2 new separate pipes run from the front 02 sensors to the Magnaflow cat. Also a small piece from the back or the cat to the resonator. Everything was welded.
Old 08-04-2006, 01:42 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Ditto.
Old 08-04-2006, 02:01 PM
Just checked again and mine is too.
Old 08-04-2006, 04:48 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
I'd be very leary about a completely welded system. It'll put a ton of stress on the exhaust studs and aluminum blocks don't take kindly to that kind of stress. Definately keep a spring bolt set up somewhere in there!
Old 08-04-2006, 06:14 PM
ok. thanks for the replies
it was exactly what i was expecting
