Old 08-01-2006, 06:01 AM
seion seion is offline
Subaru Engineer Wanabe
Need to take rear subframe out
OK, so I need to take the fuel tank out and it's recommended that the rear subframe has to be taken out first. Any advice on doing this besides taking the 4 bolts that hold it in place out? This is the first time doing this...
Cars I've worked on:
'05 Subaru Impreza STi, '02 Subaru Impreza WRX Wagon, '01 Toyota Celica GT, '98 Subaru Legacy GT 2.5 Sedan, '96 Isuzu Rodeo, '95 Jeep Cherokee 2WD, '94 Plymouth Sundance, '94 Subaru SVX LSi, '93 Subaru Impreza, '92 Subaru SVX LS-L, 2003 Subaru Baja.
Old 08-01-2006, 05:04 PM
Speedklix's Avatar
Locker Link Solution
if you have motorcycle jack and some 2x4s with the ability to cut them that'll help... or even just some blocks to rest it on to line it up. What a headache?! I can't remember 100% everything that was involved, sorry.
Tom did an AWD swap on the Stage3 and I think he posted some pics that should help you get some bearings on it.
-EDIT-
here is a pic from toms locker: subframe
You will see that the trailing link to nuckle bolt was also removed on eachside. I think that is the best way of freeing the frame from the suspension. If you have the tools, it is 100 times easier to simply cut the nut off the bolt and install a new bolt and nut on eash side when you reinstall, instead of trying to break them free as they are self locking. Be sure you unbolt those handbrake and ABS lines as well.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 08-01-2006, 06:25 PM
-EDIT-
Thanks dude, this helps a lot. It seems I will need to cut those bolts, because they are HARD to get them loose. This is going to be one @#$%*$ mission I wished I didn't have to go through.
Old 08-01-2006, 06:54 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Yeah you're not getting that tank out w/o removing the subframe unless you wanna start cutting. Just curious though. Why are you removing the tank? They don't rot! I'd love though if you can get me measurements of the tank location when you have it out. We'll need to go with a fuel cell next year for hill climbing and would prefer to put it in the old tank location. We tried to remove the tank from a wrecked SVX but couldn't get the subframe off and the tank just won't come w/o it being at least loose.
Old 08-01-2006, 07:44 PM
Fuel lines that run down the fuel tank are rusted and leaking
Old 08-02-2006, 08:48 PM
a 4ft .5" drive breaker bar is essencial in removing the rear subframe to get the trailering link arm off properly. Just be sure to get a rear wheel alignment after you are done
Old 08-04-2006, 10:30 AM
Speedklix's Avatar
15 seconds cutting 3/4 of nut
2 seconds of impact wrench
$7 for new bolt and nut.
Less effort and more time drinking... priceless.
Thats just my method, I prefer not having to do an alignment and having the new bolts in anyway.
-Mike
[SIGPIC][/SIGPIC]
